i im after some advice. I am looking to buy an audi a3 1.8t 2001, I have looked at one that has a few problems and wonder if anyone could confirm if these are common faults and easy to get repaired or if they are anything of real concern.
any comments/advice would be very much appreciated
- appears to have a small oil leak from the back of the sump possibly from thep plug. Is this a common fault as there is a lot of post on the net about this, is it an easy repair.
- the traction light remains on even when you try and turn if off?
- should the oil lamp come on when you turn the ignition on or does this only come on if there is a problem with the car? As this does not come on when you first start up (every car ive ever had has the light come on when u first car to indicate this is working)
- the cam belt has been changed but the water pump hasnât how much approximately will it cost to have these done?
