EM TuningMonster Motorsport
    Sep 2009
    102
    Oil covered spark plugs
    Encountered a lost of power and rough running. I believed a cylinder or two have stopped firing. I thought the first thing I should do is to replace the plugs. When I removed the plugs today, I found the plugs in cylinder 1 and 3 covered with oil right from the stem of the plugs down to the electrolytes where the firing takes place.
    The oil on the dip stick looked normal (not milky) and the coolant level has not dropped or changed colour.
    Do you think it is just a bad rocket gasket that cause engine oil to filled up the plug Walls and only started flowing down to the electrolytes when I was removing the plugs or do you think there is a more serious issue e.g worn piston rings, blown head gasket, blown valve seal etc??
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
    Jul 2006
    Crewe
    93
    I'd change rocker cover gasket yep.
    Sep 2009
    102
    Is there a good DIY guide somewhere?
    Feb 2008
    Manchester
    158
    here you go:
    http://forums.vwvortex.com/showthrea...highlight=3366
    this also explains how to do the half moon gasket aswell!
    Sep 2009
    102
    Thanks. Fingers cross there is nothing more serious.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    That half moon can be a right PITA to do. Mine was, even with the tool.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Spark Plugs ??
    By A3 Marky. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2011, 07:25
  2. 3.0 V6 SPARK PLUGS
    By dans3.0 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2009, 15:38
  3. A3 3.2 Spark Plugs
    By edition in forum Parts Requests
    Last Post: 3rd March 2009, 17:12
  4. Spark Plugs
    By S3fan in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2009, 23:05
  5. Desno IK20 Spark Plugs - Should I Change the Spark Gap?
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2007, 17:14
