Chris NottSky Insurance
    May 2011
    telford
    15
    Heeeeelp fmic on agu fitting fault
    Hi there I have today fitted a turbo revs fmic on my agu a3 but have a problem so here we go…
    On the standard hot side pipe there are 2 pipes fitted but on the fmic the are only 1 which is for the dumpvalve so where does the other fit 2 and its gotta go somewhere as its juddering when trying to use the boost if left off.
    I’ve searched alot of fitting guides and cant find 1 that lets you know where it fits
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    i am guessing that you mean you have taken the standard charge pipe off? Why have you had to take that off? The two outlets that come off of the charge pipe are for the dump valve and the other one is for the n75 valve
    i didnt think the fmic kits came with a new charge pipe anyway
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    It's the n75 take off that's missing mate, and it does all your boost control!
    Do not drive the car until you've sorted it, as it's very likely to do serious damage.
    Strange that you hadnt heard this, because almost every fitting guide for the turbo revs kit mentions it.
    You need a 6mm threaded hose tail, drill and tap it into the new charge pipe, and seal It up with chemical metal
    Turboman-a3's Avatar
    speed thrills
    Apr 2010
    portsmouth
    153
    Yeh it's defo the n75 I had the exact same question 6 months ago I took the pipe to a fabricator and he welded a spigot on for £20 job done
    A3 1.8T AGU (1997)
    Engine: FMIC, KO3s turbo, Silicone TIP, decat + dowpipe, custom exhaust, Yellow forge spring, R-Tech stage 2 KO3s custom map , 232 BHP 257 TRQ
    Exterior: White oem 16" alloys, debadged, white grill surround, carbon wrapped bonnet, carbon wrapped B pillars
    Interior: OEM that's it lol
    More to come!!
    May 2011
    telford
    15
    thanks gus well i did things slightly different in the end i chopped up my charge pipe and made a gap in my new pipework and integrated it in i had heard people mention it but nobody on the fitting guides i looked at showed what they meant hence i couldnt understand what they was going on about so i did it the only way i could think of and its worked fine but thanks for the replys guys
  1. FMIC Fitting Guide
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2010, 15:28
  2. fmic fitting help?
    By yellowgti in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2009, 08:46
  3. fitting fmic - any info please
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2008, 12:45
  4. Problems fitting the FMIC
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2006, 00:16
  5. fitting a FMIC to a S3
    By nwhiteley in forum Tuning
    Last Post: 4th July 2006, 18:11
