EM TuningMonster Motorsport
Results 1 to 12 of 12
    S3 Paul's Avatar
    Oct 2006
    2,764
    Finaly fitted my wideband AFR gauge...
    Well, ive had it a year now, i decided the weather was good enough for me to have a crack at fitting it,
    Im about to go out for a drive, What Numbers should i be seeing?
    The car has a hybrid turbo,
    decat 3 inch down pipe and miltek system,
    FMIC
    Jetex air filter
    other bits and bobs...
    I understand Vag cars run lean when starting to make boost whats safe and what shows a possible problem??
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    Normally go a bit lean to help boost but should then plummet to mid 12's (0.85 lambda) on boost for best/safe power
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,764
    I think i read somewhere something about ...
    11.8 to 12 on boost?
    cruising should show around 14.7 to 15?
    high 12s on cold start??
    I think that was for a mapped TT so should aply??
    Just another gauge to make me paranoid !
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    12.5 afr on boost mate... any richer kills turbine energy and power will drop... should help keep egt's down too...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    S3 Paul's Avatar
    Oct 2006
    2,764
    Thanks buddy
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,764
    Well something i didnt expect...
    When the car is on over run ( reving down in gear down hill ) the AFR reading goes to full lean. 22.4
    Im guessing the injectors shut off ? They come back on again at 1200 rpm or the slightest touch of the throttle.
    Makes sence but a little wierd the first few times it happens.
    Noggy Blue 2001 S3
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    so what were the other readings all good?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    S3 Paul's Avatar
    Oct 2006
    2,764
    Ye, I will make a note of them later, But a mate who knows a thing or two about tuning turbo cars said its all good.
    Im not sure wether the figures should be the same on all cars but... good and safe will do me !
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    Quote Originally Posted by S3 Paul View Post
    Yep.... let off the throttle with the clutch engaged in gear etc and injectors switch off... the ECU does this to help fuel economy...
    <tuffty/>
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Quote Originally Posted by ;1385079
    <tuffty/>
    Do you know if this is on all the 1.8 20v T mate?
    S3 Paul's Avatar
    Oct 2006
    2,764
    I seem to think its only on the later drive by wire cars?
    I may be wrong though
    Noggy Blue 2001 S3
  1. Wideband or non wideband lambda sensor????
    By Pedrosousa in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 19:13
  2. APR Boost Gauge Fitted!
    By mattfinn in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2008, 17:16
  3. Coilovers Finaly Fitted Today!!
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2006, 17:27
  4. K04-15 Turbo Finaly Fitted
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st December 2004, 08:29
  5. APR Boost Gauge Fitted
    Last Post: 20th October 2004, 08:22
