AH FabricationsVolks Autos
Results 1 to 9 of 9
    Sep 2011
    Rotherham
    55
    Banging noise comming from near side.
    Can anyone help me, i got an audi a3 1998 and theres a banging noise comming from the near side. Sounds like somethings banging on the underneath the car.
    Apr 2011
    London, United Kingdom, United Kingdom
    115
    wishbonem probably, had mine changed and the bolt was getting loose. just had it re tightened
    Sep 2011
    Rotherham
    55
    Cheers mate ill check it out, are they expensive?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    More than likely a drop link. Thats the most common cause of a knocking nowadays. This is BY FAR the most common suspension item I renew at work for this problem.
    Not ruling out other things, just that in my experience, they are the main culprit.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Sep 2011
    Rotherham
    55
    Any way to check without buying new ones?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    jack the front wheel up, get under the car (making sure you're safe with axle stands or the like, obviously) and grab hold of the antiroll bar and push it up and down, if a drop link ball joint is worn, you'll feel and hear the play. Do the same on the other side to check that one.
    Suzuki GSX-R 750 K5
    Sep 2011
    Rotherham
    55
    was just reading all the recipts that came with the car and i found the last MOT advisory says Near side suspension arm rubber deteriorated, near side outer track rod end join cover missing. Guessing all that counts for the noises. Can you buy them in ones or do i need to buy them for both sides?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Yea, could well do mate. Best to get it into a garage and up on a ramp really. If you're anywhere near Northumberland I could check it out for you.
    Things like wishbones, drop links, track rod end ball joints, tie bars etc are just done seperately, its things like shocks, springs, brake discs/pads that should be renewed as pairs.
    Suzuki GSX-R 750 K5
    Sep 2011
    Rotherham
    55
    Thanks mate your a star. One last thing, is there any websites with cheap A3 parts or is it best letting garage get them? Thanks alot.
  1. help noise comming from breake
    By alfie155 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th September 2011, 16:39
  2. a3 rear suspension big banging noise when going over potholes
    By jellyfishpants in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2011, 11:20
  3. 1.9 TDI weird noise from passenger side
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2010, 22:37
  4. banging noise from back end, help any1?
    By JonnyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2010, 18:56
  5. Banging noise on driver side.
    By hardytangi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st January 2010, 18:10
