Volks AutosBadger5
    Sep 2010
    498
    Changing front ARB Bushes
    Noticed today whilst fitting my 312mm discs that the front ARB's look like they need replacing. Theres a big gap between the bar and the bush.
    It looks easy to replace. Just one nut by the looks of it. Is this correct?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    bit of a pain as theres not much hand room down there. but pretty easy. just make sure you get the correct size bush
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    If you struggle to get the collar over the new bush, use some mole grips / water pump pliers to close the gap a bit more. Or you could get a slightly longer bolt and use that to close the gap before putting the proper bolt back in...
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Sep 2010
    498
    Excellent. Thanks guys.
    Jun 2003
    west yorkshire
    90
    If you are only changing the bush's just make sure that the plastic lug / spacer isn't split or brocken as you will then need a new bar.
  1. Replies: 0
    Last Post: 23rd October 2010, 20:43
  2. Is it really worth it? Changing bushes/suspension etc
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2010, 13:35
  3. What bushes are worth replacing when changing suspension setup?
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2010, 15:49
  4. Front ARB bushes ??
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2010, 20:33
  5. Changing top mount bushes/bearings
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 17:38
