Monster MotorsportVolks Autos
Results 1 to 8 of 8
Thread: cluster removal
    dusty's Avatar
    Nov 2010
    nw england
    144
    cluster removal
    im going to be removing my cluster at the weekend, so that my d.i.s. can be replaced as its barely readable, does anyone know if my cluster will need re coding with vcds when i re fit it, or does it only need re coding if i replace the actual cluster thanks
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    I think only if you replace it, i've had mine out and back in with no problems
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    dusty's Avatar
    Nov 2010
    nw england
    144
    thanks for clearing that up for me, didnt want to take the cluster out without knowing for sure
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Had mine in and out a few times over the last week while attempting my RNS-E retrofit. So yeah you dont need to recode it when it goes back in it does lose the memory of the time setting etc but thats it.
    The only advise i read online was that you shouldnt turn on the ignition when you have the clocks out as people have said it can make the immobiliser go a bit funny and wont let you start the car afterwards. So i just made sure i didnt do this.
    There are 3 plugs on the back of the clocks a blue a grey and a green one of which one was a pain to undo and plug back in as the cable is a little short.
    I took the plastic cover off my clocks whilst i had them out to give it a bit of a clean and also remove the dead fly that had managed to get inside there.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Quote Originally Posted by vrbob View Post
    My clocks been taken out for several times and Never had any problem with it
    Currently not in the country
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    No probles at all, as said dont turn the ignition when the clock are out just to be on the safe side, and make sure you post up you results and if time a how to guide
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    to get the clocks out is a peice of cake.
    lower the steering wheel and pull it out as far as it will go.
    There is a piece of trim just below the clocks which you just pull off.
    Behind this are 2 x philips screws (they can be a bit tight to undo) remove these.
    then using the 2 little things you use to reset the odometer etc just pull the clocks out so that you can access the back to undo the 3 connectors.
    the connectors have an arm on them that needs to be moved upwards to release it from the clocks.
    Refit by doing the reverse.
    dusty's Avatar
    Nov 2010
    nw england
    144
    thanks for the replys, i may take a few pictures and try and do a bit of a guide my computer skills are very limited though, my mate is doing the actual d.i.s replacement will let you know how it all goes
  1. Cluster removal
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th October 2013, 11:18
  2. Back light cluster removal
    By Block 405 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th August 2009, 17:32
  3. Removal of rear light cluster
    By steveos3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2009, 21:11
  4. Speedo cluster removal
    By NellyJ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2007, 13:31
  5. Rear Cluster Removal
    By Mahatma in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2007, 21:06
