EM TuningBadger5
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By finesse
Thread: Problem with alarm on my 1999 a3 1.8 T
    Jun 2011
    12
    HI I'VE NOTICED WHEN MY ALARM GOES OF ON MY CAR THE INDICATORS FLASH BUT NO SOUND FROM THE SIREN/HORN
    COULD SOME ONE PLEASE SHED SOME LIGHT ON THIS PROBLEM.
    REGARDS DAN
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Commion problem as I understand it, battery in alarm is dead, I "think" theres a thread on replacing it mines the same but cant be arsed to replace it.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Jun 2011
    12
    Quote Originally Posted by sportquattro View Post
    I've tried finding the thread but can't seem to find it. You wouldn't happen to know where abouts the box is so I can try replacing the
    Battery's? Cheers
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Written by JohnH on the TTForum
    ALARM SIREN FIX- HOW TO
    The alarm siren on the TT has a limited battery life and has given quite a few people trouble. The first symptoms of failure are a series of beeps from the rear - usually on a cold morning or after not running the car for a while. This means the rechargeable Ni-Cd (or more correctly Ni-MH) battery is getting old and can no longer hold it's charge and maintain it's voltage under load.
    Replacement or fix?
    You can either get the dealer to replace it for �140, buy the part yourself (P/N: 8L0 951 605 A) for �70 or buy two replacement batteries from Maplin or the like for �10 total and fix it yourself (Maplin Order Code: BN24B [2 required]) . Your choice.
    Tools
    If you decide to fix it you'll need:
    10mm ring spanner or similar
    Dremel saw or junior hacksaw
    Soldering iron and solder
    Hot melt adhesive gun or similar
    Some wire and insulating tape.
    Procedure
    The unit is relatively easy to remove as you can see in Wak's guide:
    Waks Wide Web which involves taking the rear light cluster off too.
    I found you can get the alarm unit out easy enough through the inspection flap without removing the rear light cluster. You can see it here.
    You just need to use a small 10mm ring spanner or similar. Reach round the back and loosen the single nut in the middle of the back of the unit. Once it's loose you can remove the nut with your fingers - be careful not to drop the nut! The Alarm can then be unplugged and removed.
    Once you have the unit out you need to perform some surgery. The case is made from thick plastic and is welded and sealed extremely well. Basically you need to cut into the plastic case along the weld seam. You can see the line here 20mm from the edge of the speaker opening. For this you can use a Dremel type tool. I used the 25mm diameter circular saw attachment. You could also use a junior hacksaw for a more controlled neater job. Cut along the line but don't cut on the speaker side of the line otherwise you may cut off the bezel and not actually open the case . Cut about 1mm to the other side of the line away from the speaker opening.
    You need to cut about 4mm deep all the way round. I left a little under the connector to act as a hinge - not strictly necessary but the prongs in the connector, which come from the circuit board, need to swing clear of the connector aperture, so it helps.
    Here you can see how thick the plastic is. Don't cut deeper than necessary or you will cut through the circuit board support pillars.
    The circuit board has two spring contacts which make contact with the battery you can see at the back of the unit. Unfortunately in this case the battery had leaked and corroded the contact and actually unsoldered it from the circuit board. This alarm siren had been dead for some time. If you catch your siren early enough (when it's still beeping) you shouldn't have this problem as the battery will not have leaked.
    Watch you don't zap the electronics with static electricity from walking across a nylon carpet or similar. Best to earth yourself by touching a tap or earthed item before handling.
    Here you can see the circuit board unplugged and unclipped.
    Here you can see typical damage to one of the PCB battery connectors, caused by acid leaking from the battery.
    The leaking battery can detach the connector from the PCB if it has been leaking for long. Here you can see that the corrosion has penetrated through to the other side of the PCB. This might just respond to cleaning with IPA and a toothbrush but in some cases the solder joints may need repair.
    If the acid has eaten away tracks and components, as in this example after cleaning, the circuit board is beyond easy repair.
    As a reference, here's a high resolution image of an undamaged circuit board:
    Now for the thing that causes the problem...
    Here's a close up of the Ni-MH battery. There are two of these 3.6V batteries wired in series to give 7.2V. If you can find a readily available source you could just replace them.
    Unfortunately I've been informed that the only manufacturer Emmerich, a German company, has ceased trading. Their battery was a 160mAh capacity but in it's later production form had been superseded by a slightly increased capacity 170mAh version. The Full specification was:
    Ni-MH three cell stack
    3.6 V nominal voltage
    160 or 170 mAh capacity
    320 mA maximum discharge load current
    22.1 mm diameter
    11.6 mm height
    15.5 gms weight
    There is an alternative. These "3V" described nominal 3.6V Ni-MH batteries from Maplin are rated at the same 160mAh and are a suitable equivalent.
    As you can see they are a similar size but a different shape with PCB contact pins. If you use them, you need to remove the old batteries and cut away the plastic that held them, in order to make enough room for the two new batteries.
    Make sure you observe the original polarity of the old battery. You need to solder the new batteries in series and solder wires between the new batteries and the two spring connectors on the circuit board. The spring connectors can be unsoldered and removed or cut back to make attaching the wires easier and neater.
    The new batteries should be wired in series so that they make one big (twice voltage) battery.
    Here's another view: >
    Then the overall 7.2V battery needs connecting to the circuit board with the same polarity as the original batteries. Look at the way they were connected. You can see here that the original +ve connection from the old battery is in the lower part of the picture. This must also be the +ve connection from your new battery assembly. The -ve connection must go to the upper of the two PCB battery connections in the picture.
    Remember the new batteries will be charged, so it is important not to short them out or allow them to make unintentional contact with the circuit board components. Construct the battery assembly separately and insulate well before gluing to the case and soldering it to the circuit board.
    Here the battery has been shrink wrapped in adhesive heatshring tubing. After doing this I filled the exposed ends with hotmelt adhesive to form a seal in case the battery should ever leak in future.
    The two PCBcontacts are best having their spring prongs snipped off so two flat pads remain as a good anchor point to solder on the wires (RED = +ve, BLACK = -ve).
    You can glue the new battery assembly in place with hot melt adhesive or similar. It should go in the same position as the original batteries so it clears the protruding transformer on the circuit board. The plastic holder for the old batteries can be broken away to make room. Make sure none of the battery contacts are exposed and likely to touch the circuit board or that three pin connector. Adding some insulating material to protect it is a good idea or heatshrink if you can get it.
    You can test the electronics at this stage by plugging in the connector to the car being careful not to allow anything to short out. There should be a slight click from the speaker. If you have "beep on locking" enabled you can test it with this function, or set the alarm off by waving your arm through the window.
    If the alarm doesn't work and you have a multimeter, measure the battery voltage. If it's much lower than 7.2V it might need charging, so you could leave it plugged in to see if it recovers. If the voltage is 7.2V or thereabouts it should have worked and this might indicate you had further PCB damage from the acid . You could try cleaning again.
    Finally, if all is well, the case can be closed up and held together with some hot melt and some tape. Make sure the three prong connector pokes through the connector tube centrally. As good as new
    P.S. If you were unlucky and your unit did not work because the acid damage was too great, ask your local Audi dealer for an old returned unit. They only go into a recycling bin but you can do a much better job than that - have another go and save wasting your new batteries
    renton likes this.
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Feb 2011
    Somerset
    6
    looking in the boot.. left hand side
    you have to take the muti cd out, then the sub woofer, it sits right at the bottom of the wheel arch...
    Jun 2011
    12
    Cheers for the info :-)
    Jul 2011
    169
    Can u remove the alarm and it still be ok to drive the car
    The weapon of choice... The a3
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by lnewland View Post
    just leave it instead and itll be fine lol
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Jul 2011
    169
    So where do u stand insurance wise if u have told them there is an alarm but u know it's not working
    colicabcadam
    don't tell them it's not working, simples lol
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    How they find out that the alarm is not working??
    Currently not in the country
    Jun 2003
    World of my own
    9,813
    Whether it works or not is really irrelevant as it sounds like a clock radio alarm and wouldn't alert anyone if your car was broken into, get a decent aftermarket unit if you want an alarm that actually works properly.
    Alex Turner
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Iv got a toad alarm fitted and it plays silly beggers not letting me in and so on, was done by previous owner with no reciepts, wish i could have the old fob work again
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by AndyMac View Post
    oh in that case mine works then. as i thought that was the result of it not working properly. i get the stupid beep beep beep but i thought it was like a big siren or the car horn or something
    Sep 2012
    Would the alarm still function when the 3 beeps come on ? I get the beeps every so often, just set the alarm off and the siren is ringing. Is this a sign i need to change the battery anyway or not ?
  1. 1999 a4 window problem
    By adelle in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2011, 20:43
  2. Strange problem!! 1999 S3
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2009, 12:17
  3. 1999 1.8t quattro alarm.
    By daveeeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2009, 23:49
  4. 1999 s3 with Factory Audi cat1 alarm
    By HmanS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2007, 12:04
  5. alarm siren A3 tdi 1999
    By noddy tt in forum Diesel forum
    Last Post: 18th August 2006, 12:29
