Sky InsuranceVolks Autos
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    traction / ABS light coming on after 10 mins.
    hi
    my audi a3 1.9 tdi 130bhp.
    from starting the car i would say 8 minuets exactly could be 10 mins the abs / traction control light comes on and stays on until you tun the engine off.
    when i start the car back up its the same process exactly after 8 or 10 mins ( i could do with a stopwatch )
    this has only occured since having cruise control fitted.
    i have took the car back to where the cruise was fitted and it was put on the diagnostics to find a fault " load signal from alternator "
    the fault was cleared but it keeps popping back up.
    im looking for information on this please if anyone has had the same problem etc .....
    i dont want to go out and spend nearly £200 on a alternator if this isnt the problem as my alternator doesnt look that old.
    hope someone can help
    :D
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    bump :-)
    Inertiauk's Avatar
    Mar 2011
    529
    You don't need a new alternator, Just a wiring repair ....How to: Fix broken Load Signal cable from Alternator - SEAT Cupra.net - SEAT Forum
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    yeah cheers or the reply on this i did see this a while back when i made this post
    i got my car in the air had a good look about and couldnt find this conection.
    being a audi a3 i though it would be different with that being a seat on that website ?????
    weather there all the same i dont no ??
    if i didnt look hard enough etc ,,,,
  1. Traction Control Warning Light Coming On
    By adamf200 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2011, 09:46
  2. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  3. ABS Light & Traction Control Light On??
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2009, 12:00
  4. Traction Control Light coming on intermittently...
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 21:55
  5. Traction Control Fault Light coming on...
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2005, 13:52
