AH FabricationsBadger5
Results 1 to 10 of 10
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Diagnosing which wheel bearing is dying...
    The S3's poorly lol! Got a whining drone from one of the wheels and a squeak once per tyre rotation when doing between 5 and 20 mph... I've had the wheels up and spun them and there's no play in any and I can just hear the rear pads grinding in the sticky calipers lol. What's the best way of diagnosing which bearing is dying?
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Wel id say its probably the fact that your rear brakes are grinding,that would cause that noise!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    May 2011
    80
    as above! have you tried listening whilst cornering to see whether the noise worsens or reduces depending on which way vehicle weight is shifted?? not scientific but may narrow it down....usually ive just had both fixed if i cant find evidence to suggest recent replacements by previous keepers that way i know both are good.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Well one of my rear ones has finally gone, started squeaking 2 week ago, now its scraping and grinding, sounds shocking lol.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    The way to diagnose a wheel bearing isn't just to spin them, hold the wheels at 2:40 and then 11:20 and push and pull them back and forth. The noise you get is when the bearing gets worn and moves up and down the taper bearing face. Just suspended and spinning they probably won't sound too knackered.
    Does the noise go away when going round a corner? If so left or right hand corner?
    I quite often say I'm going to do things.
    Then never do them.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Pretty sure mine goes away when doing right hand corners, ill double check tomorrow though.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Do we have taper bearings? I thought that they were cartridge units so won't wear in the same way to give the play of a taper bearing?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    They are cartridge yes, sorry I didn't explain that very well did I.
    The cages around the bearings are what keep them tight, as they were the bearings move up and down in them.
    Then never do them.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    There is very rarely any play in a knackered roller bearing due to the way they're clamped together.
    The one i've just removed from the front of the A4 sounds like theres gravel inside when your turning it by hand, and howled when driving along, yet exhibits no play whatsoever.
    I identified mine by spinning the wheels, you need to give it a really hard spin though to hear the bearing over the brake pads as you've described.
    TD5 Land Rover Defender build
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    OK, cheers. Think i'll remove the pads and give em another spin
  1. Wheel bearing going?
    By GeoffT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2011, 16:52
  2. Wheel bearing on it's way out?
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2011, 10:31
  3. A3 1.8ts wheel bearing ???
    By Paul251 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2009, 21:54
  4. Wheel Bearing
    By A3DOL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2009, 15:45
