AH FabricationsSky Insurance
Results 1 to 7 of 7
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    clutch and flywheel collapse
    thanks to everyone who replied to my earlier threads! much appreciated. After lots of head scratching problem turned out to be the dual mass flywheel collapsed, destroying the clutch at the same time.
    I have found a clutch/flywheel kit on ebay for £150: Audi A3 TT 1.8 T 1.9 TDi Flywheel, Clutch, Cylinder 96- | eBayas anyone got any experience of these, are they worth getting or should i just fork out for a VAG one?
    Also my mechanic is concerned that there are many different sizes of clutch for these? is this right? i thought it was a simple matter of checking my registration number against the database?
    cheers
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,063
    it would probably be worth you saying what your car is so we can give you advice on what you need to buy mate!
    from the ebay link you posted, I'll assume it's a 5 speed 1.8T A3.
    If that's the case, then what you need, is a mk3 golf 2.0 16v flywheel, from an ABF engine, and the 6 bolts that hold it to the crank.
    Then you'll need a clutch kit from a mk3 golf VR6, engine code AAA.
    These will fit your 1.8T engine and 02J gearbox, and give you a clutch capable of holding 300lbft, a ligther pedal feel, and a ligther rotating mass giving better pick up and acceleration.
    I paid about £160 for a brand new flywheel from TPS, and £90 for a clutch kit from GSF
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,522
    Snuff's Avatar
    satan's driver
    Aug 2011
    darkest caerphilly
    56
    i got a 2003 S3 and my clutch is going . what is the best to fit in its place ,its remapped and i would rather stick better bits back in than standard ones
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by Snuff View Post
    I'm using a helix paddle clutch, it's heavy as fook but damn you can give some serious abuse
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    Sep 2011
    tiverton
    337
    just had a valeo clutch fitted and changed to a solid mass flywheel, car actually drives much smoother now and is just as quick as it was before. car is
    a tdi 110
    total cost was 456.49 including recovery, parts and labour so not too bad i thought
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I've just fitted the valeo solid flywheel kit to my A3.
    about £180 for the kit and £120 for fitting so £300 all in
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
  1. New clutch and flywheel...
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd March 2011, 17:51
  2. HELP... Clutch or Flywheel
    By mark.colledge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2011, 23:11
  3. 20v G60 Flywheel & VR clutch
    By steviet in forum Sales Questions
    Last Post: 13th April 2010, 14:46
  4. Clutch And Flywheel
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 20:54
  5. New Clutch & Flywheel!!
    By smiles in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2010, 19:46
