Chris NottMonster Motorsport
Results 1 to 10 of 10
    Nov 2004
    37
    A3 TQ transmission problem
    Hi, first poster here!
    My A3 TQ has developed 2 problems which may be related
    1. A loose rattle/clunk from somewhere underneath, heard when bouncing over potholes at low speed.
    2. A droning/resonance at 2900-3000 reves (in all gears, whether accellerating or decellerating, but not when revving in neutral)
    I have recently had the engine mount bushes replaced but problem 1 predates this.
    I have the car booked in to my local specialist next week but I would appreciate any comments or suggestions in the meantime.
    Jun 2003
    World of my own
    9,813
    Re: A3 TQ transmission problem
    The droning could be a wheel bearing, but this is normally speed rather than rev related.
    Nov 2004
    37
    Thanks Andymac. The droning I hear is definitely rev related rather than speed related. More likely transmission than wheel bearing?
    The knocking noise is what worries me more.
    Dave
    Aug 2003
    Surrey
    469
    have you had exhaust checked? Maybe it's breaking up somewhere or moving too much. I had to have the rear box replaced on mine at about 40k miles as it was making nasty high pitch scraping sounds and clanging about over bumps, but I guess you'd already have been able to tell if the noise was more exhaust than engine.
    Worth a look at exhaust and heat shield anyway.
    Nov 2004
    37
    Thanks BK1.
    I have had the exhaust mountings checked and they seems OK.
    Engine mountings & suspension have also been checked and are OK.
    it is the droning/resonance at 2900-3000 revs that makes me think the noise is coming from something loose or worn in the transmission.
    Nov 2004
    37
    What would cause droning/resonance at 2900-3000 in every gear? Transmission? Gearbox?
    all suggestions welcome.
    Feb 2004
    UK
    1,320
    clunks could be arb's.
    Nov 2004
    37
    Ryanc,
    excuse my ignorance, but what are arb's?
    Nov 2004
    37
    TAL (Thanks a lot)
    Dave
    Nov 2004
    37
    Re: A3 T Quattro transmission problem. Please help!
    OK, had the car checked out today. From underneath, the suspension, anti-roll bars and exhaust all look fine, so the clunk is not coming from there!
    I sometimes feel a vibration, possibly from the transmission tunnel, when pulling away or even idling (at the end of a journey when everything is warmed up). The clunk then becomes really obvious over bumps!
    My suspicion is that the problem lies in the driveshaft or somewhere along the transmission.
    Is it an expensive job to strip off the exhaust and check out the driveshaft?
    Does anyone have similar experience of this?
    Any other ideas or suggestions?
    This is really bugging me now!!
    [img]/ubbthreads/images/graemlins/thumbsdown.gif[/img]
