Chris NottVolks Autos
    Nov 2004
    Hosrham, West Sussex
    390
    Traction control light staying on
    1st time it's happened. Noticed on the way in this morning that the light was on ... couldn't turn it off with the ESP button [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Restarted car and it's off again, will get VAGCOM plugged in tonight - any ideas? Seen this before?
    Cheers!
    Adam
    Nov 2004
    Tonbridge, Kent
    912
    Re: Traction control light staying on
    Does your ABS light come on as well?
    Mine did this and apparently the ESP cannot work without the ABS so both should come one. It turned out that mine was due to a faulty acceleration sensor that got replaced. However it can be due to the wheels not being balanced as well.
    The garage cleared the fault, but replaced the acceleration sensor for good measure. (under warranty)
    Hope it helps mate
    Rob
    Middlesex
    141
    Im sure the the ESP Light comes on if you disconnect the MAF, so maybe related to that?
    Jun 2003
    44
    same problem with mine a few months ago. Mine was the longitudinal sensor - dealer wanted about 900 IIRC. Although, Audi UK contributed about 400 in the end.
    CARACTERE007's Avatar
    havin\' a giraffe
    319
    umm i had the same problem but mine was the lateral acceleration sensor, 300 later it was sorted.
    Nov 2004
    390
    Not come on again since, will read the codes this weekend.
    ...have Audi warranty until Dec so hopefully a repair wouldn't sting me.
    Cheers,
    Adam
