Results 1 to 7 of 7
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    2 problems i need advice on......
    First one.
    Whats the best way of tightening up the front upper strut nut, the 21mm nut that sits in the front upper strut seat? Ive got a 21mm drop spanner and ive tried using a 11mm socket and spanner the dampener but it just doesn't seem to tighten up, there's so much force on it but yet it loose!
    Secondly.
    Ive found out the rear hub has lost its threads, thats why the rear suspension set-up had a nut and bolt instead of just a nut! Whats my options, can i use thread lock? can it be re-threaded?
    Dan.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    There are 2 nuts at the top of the strut one on top of the bearing, and the final top nut that you do up once the strut is on the car, if the lower nut is not done up tight then it will clonk and no end of tightening the upper nut will help, I had this problem recently when fitting my Bilstein B8s if you remove the top nut and the metal plate you should be able to get at the lower nut and tighen it, if it wont tighten then youll need to release the spring tension with spring clamps and tighten it. Hope this helps
    Nige
    Last edited by sportquattro; 25th September 2011 at 17:34. Reason: The usual lousy typing
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    No, sorry mate, i mean the top one, not the one that holds the bearing and top mount in place. Ive been told to go to a garage and get them to use a airgun/impact wrench as thats the best way.
    Sep 2009
    741
    if the lower nut is not tight, it wont matter how tight you do the top nut it will still clonk, if the top nuts not tight of course then an air wrench will sort that aspect for you but I'd be surprised if you've used a drop spanner and allen key in the strut if you've not been able to tighten it but hopefully the air wrench will for you.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    Air gun and pulse it on as opposed to just holding the trigger at full whack is the way I'm told!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Quote Originally Posted by sportquattro View Post
    Yeah its quite tight, to the point where the 11mm dampener fixing is staring to shear.
    Think im may just nip to kwik fit and get them to air gun it.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    think mine was a allen key iirc, so I ground 2 flats on a socket, allen key through the middle then spanner on the flats on the socket.
    red to red black to black blue to bits
  1. TDI 140 sport Turbo problems - Some advice
    By Stink in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th August 2011, 10:01
  2. A3 braking/abs light problems any advice please?
    By craigd in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:10
  3. Steering problems, I need some advice
    By jwhat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st December 2009, 23:53
  4. engine problems advice needed
    By 20s on a tt in forum TT/TT-S/TT-RS Forum
    Last Post: 31st March 2008, 10:26
  5. Cutting out problems, any advice?
    By imported_smoke in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2005, 18:16
