Sky InsuranceChris Nott
Results 1 to 13 of 13
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Question Wheel bearing? Easy? knocking noise
    still in process of trying to sort out my rear knocking noise, done drop links as advised by Audi in the health check. and its still doing it.
    so thinking about changing the rear wheel bearings, just wondering is it something i can do on the driveway on axle stands? or is it a garage jobbie?
    also anything else i could replace whilst at it?
    Cheers guys
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Requires a special tool iirc as they are pressed in.... they are a sealed unit bearing...
    I have only ever done front bearings and they require a press, from what I remember reading the one time I looked at it the rears can be done in situe but will need tools...
    Here is a link to doing the fronts for a reference...
    VWVortex.com - Wheel Bearing and Hub Replacement DIY
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Ive got a right rear end knocking, its loud as hell, only started after i fitted my coilovers bit i know a wheel bearig has gone as i can hear it squelling lol.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Only happens if do a sharp left hand bend, like most roundabouts. I didn't think wheel bearings made a knocking noise but I'm stuck on what else it could be.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Knocking from the rear when loading up around corners is almost always the drop links...
    Sealed type wheel bearings don't tend to knock unless you have a more serious issue... jacking up the rear so the wheel is off the ground with the handbrake off and rocking top/bottom then side to side should give an indication of the wheel bearings state... usually only moves on roller bearings, not seen a sealed unit do it yet...
    Tie bar can be check by grabbing it and pulling it back and forth towards the inside of the car rather than front to back... best done with both rear wheels off the ground so the ARB isn't loaded up...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Changed the drop links for brand new ones, any ideas?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    just had a quote from a local garage to replace nearside wheel bearing at £95. sound fair?
    or is there something else i can do before forking out nearly £100?
    Aug 2011
    160
    Drop links make a light knocking noise over uneven ground. Knocking when taking corners could be the exhaust system hitted due to old and worn rubbers. Also check the anti-roll bar 'mounts', worn rear trailing arm bushes or rear broken springs.
    Let us know would you get on mate.
    Audi A3 1.8T AUM Sport with more doors.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    An you buy powerflex exhaust bushes or are oem best?
    Aug 2011
    160
    If that is the issue then oem ones work well, most mk4/8L platform cars still have the same exhaust rubbers they came with from birth.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    I'd never put a knock down to a wheel bearing, they whir and whine.
    I have a knock after fitting an r32 arb but i know its drop links as they flop around loose as a hooker when not connected.
    Im rebushing the whole rear end tomoro so ezpext a write up in my thread.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    You fitted an r32 arb? At last how you finding it?
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Yeh si! It brings the car to life! Love it!
  1. Whining noise - Its the wheel bearing right?
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2012, 08:56
  2. Wheel bearing noise turned out to be the bloody rear diff, please help
    By Major Lucky in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2011, 20:33
  3. How easy is a rear wheel bearing to fix on a tdi B5??........
    By themelv in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2010, 10:46
  4. A6 rear wheel bearing noise?
    By imijut in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2010, 21:36
  5. Strange Noise - Wheel Bearing ?
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st July 2009, 18:22
