AH FabricationsEM Tuning
Results 1 to 7 of 7
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Exclamation A Few More Catch Can Fitting Questions??
    I've been looking at the guide posted on here and I've got a few questions.....lol
    1. This isn't just c a catch can question ... I want to remove the relay box and mount the can there but in the guide it says to just remove the relay and tuck in into where the wire come out.
    My relay box has two relays in there so my question it, What are these relays and will they both fit in that compartment?
    2. What do you guy use to plug the holes that are left behind ?
    3. It looks like the hose that comes from the catch can inlet goes to the top of the manifold a T’s off to the front of the engine, but i cant work out where that is.
    Thanks for any help given
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    Quote Originally Posted by A3 T View Post
    ...this is a marks and spencers catch can question?
    not sure what they're for. I have seen people tuck them into the plastic ducting before, i see no reason to not be able to squeeze two in there. I think people have wrapped them in a lil plastic bag too, just in case.
    Was it you who routed you boost gauge pipe through there? Remember how much room there was?
    What holes? The idea is to then remove the relay 'carrier' to make room for the catch can. I think someone even modified the relay carrier braket to carry the catch can for easy removal. Good work to whoever that was.
    I think you mean the pipe that goes to the crankcase breather which is on top of the oil filter housing
    Q.
    A question i have for people is that the original system used the vacuum from the inlet manifold and the PCV valve to draw the blow by gasses out of the crankcase. Looking at the guides this vacuum feed from the inlet manifold has been deleted. I guess that the vacuum isn't necessary to draw the gasses out of the crankcase?
    A. ___
    Use a separate sheet of paper if you need additional space
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Cant remember what they are for but both will easily fit into the eire ducting to the right of it.
    What holes do you mean?
    The inlet of the can comes in from the rocker cover, the T'd bit goes down under the inlet mani and into the top of the oil filter housing. You will see this if you follow the dipstick down.
    The can outlet can then vent through the hockey puck and back into the TIP or scrap the puck and vent to atmosphere.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Sorry i should have been more clear but i was half asleep when i made this thread (a bit like i am now....lol)
    I found this on another site:
    and on the TT its the same fuse box but they do different things:
    The guide says you need to cap off the vacuum source under the manifold , the brake booster and the hole in the TIP
    The last time i had the sai/n249 plate off i had a look but i couldn't see anything that matched up with he pic in the guide
    Westy's Avatar
    Dec 2008
    17,273
    Mate I seriously cant make it any easier for you, bar coming round and fitting it
    See all the pics halfway down the page:
    Guide - How to fit a catch can and simplify the PCV system
    T
    he only difference with the diagram in the above thread is that is shows venting back into the TIP where as I now vent to atmosphere and have blocked up the TIP.
    S3 Build Thread
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by Westy View Post
    T
    ok mate ill read the guide a few more times....lol
    Westy's Avatar
    Dec 2008
    17,273
    Just re-read the bit in the link, its the revised guide I did to try and make things a bit more simple.
    S3 Build Thread
  1. Fitting a catch tank to my AMK S3 Help please
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2011, 19:35
  2. BSH Catch Can - Being changed for a Forge Catch Can (8P2 new configuration)
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2011, 15:35
  3. Rns-e fitting questions
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th November 2010, 15:06
  4. S3 Catch can effluent - What has my catch can caught this month?
    Last Post: 15th November 2009, 11:30
  5. Any one tried fitting an oil catch tank on S3
    By 4real in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2008, 17:30
