JMB RetrofitsSky Insurance
Thread: r-tech remap
    May 2011
    telford
    15
    r-tech remap
    hi there i have just contacted r-tech about getting my t-sport remapped i have the following spec its a 98 agu engine with a k03s turbo / 3" decat pipe / stainless steel backbox / uprated recirc bov / piper x induction kit / and im gonna change my uprated smic for a fmic i have been told the map i need is a stage 1 custom map and im just wondering if anybody has this map with similar mods and what sort of power figures i can expect from it ?
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    looks like the 1.5 map should see about 220bhp.
    When u come to sell ur uprated smic pm me
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    May 2011
    telford
    15
    thanks dave i did ask the guy i spoke to at r-tech but he said he wouldnt give estimates until i got the car there and he had a look at it but i will be happy with those sort of figures for now im gonna rebuild and uprate the engine internals as i eventually want to get some bigger power figures out the car and run a gt28 turbo i have also been wondering and maybe you may of seen a thread if there is 1 but can the agu block be bored to say a 2.1 ? or what parts would i need to change in the block to hold say 300-350bhp safely all info or links would be great
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Quote Originally Posted by chesh1980 View Post
    Search would be your first option, there is quite a few big turbo threads on here for you to look through... check out the stickies as there is big turbo info in there too..
    Only one member on here has had the balls to go 2.1 and its not a small (or cheap) amount of work... you can buy stroker kits that will take the 1.8 20v to 2ltr though (info in stickies and try a Google for Integrated Engineering)
    No need to go 2.1 tbh... you can get 350bhp easily enough with a 1.8... if you need new pistons or a rebore then safest max size is 82.5mm... you can go 83mm but then its getting close to the bores being very thin and only recommended if you plan to race the car and life the block...
    Internals wise then typically all you need to do bottom end wise is change the rods as these have a habit of bending, stock pistons are strong enough for over 400bhp...
    Top end wise you already have a large port head so a good start... no real need to go for valves and springs on a GT28 just make sure the exhaust guides are replaced though as these wear and can lead to valve failure at the higher revs you will need to make the most out of a BT
    <tuffty/>
  1. S3 Remap, R-Tech or AMD?
    By RobD88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2011, 10:43
  2. Remap at R-Tech
    By Sanj in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 13:57
  3. My remap day at R-Tech :D
    By S1MON A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2010, 11:17
  4. R Tech Remap
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2009, 23:44
  5. R-tech remap
    By c_dog in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2008, 22:39
