Page 5 of 10 FirstFirst 12345678910 LastLast
Results 161 to 200 of 373
Like Tree9Likes
Thread: XS Power Downpipes & Manifolds
  1. #161
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    I'll be fitting mine in the 1st week of Jan Jim, so I'll let you know how simple it is! From memory, due to the shape of the manifold, spanner access is almost non existant to some of the bolts, so I'll have to wait and see how best to tackle it!
  3. #162
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Westy what gaskets did you use when doing the DP and decat?
    4 Rings did the job for me as they removed the turbo and fitted the new one.
    As far as I know they just used OE gaskets from Audi and I'm sure it's only the 1 gasket that you need. But I'm not 100% mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #163
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Thanks. Appreciate your help. I'm just weighing up whether to get stuck into the whole manifold, rods, head and hybrid experience.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
  5. #164
    Jimgrim77's Avatar
    Nov 2011
    957
    Quote Originally Posted by Westy View Post
    The manifold is not an easy thing to change. Most will remove the cylinder head to get at it.
    With the head off you will need a new head gasket and timing belt. Also whenever doing the timing belt it's a good idea to do the water pump too.
    You can make this job as involved as you want In terms of work and replacing parts.
    You may want to get the turbo checked or refurbed while you're near it. It would also be a good idea to do the DP at the same time. With the head off you might want to get that checked over or change the rods for forged ones. The list is endless.
    Even if you only wanted the mani fitted it'll still end up bein an expensive labour bill as it's quite a big job.
    Thanks westy.
    Very informative and lots to consider. I'd assumed, like any mod, that one thing very much leads to another and this is no different.
    I'd love to see the performance difference in the vehicle with all of the above in situ compared to mine.
  6. #165
    Chugger
    North Devon
    2,716
    I was always under the impression that it was a head off job. I'm tempted to do mine as mine manifold has a crack in it. I'm happy to have the head off and fitting a new headgasket etc, although I have done the timing belt a few times on other cars im not sure I'd be confident enough to do it on mine... Although massively tempted to give it a go.
    57 A3 2.0 TDI Sportback (140)
  7. #166
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    I have removed the manifold in situ and removed the head to access it needless to say if i ever have to remove it again i will certinally be removing the head to do it, a tubular manifold im sure will give you more room to work with between the runners than a cast one but i would advise still removing the head
    You could also find a tight one that draws the stud out with it which again will be a complete pita
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  8. #167
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Downpipe will need a Turbo - DP gasket from Audi, and also a generic 3" flange gasket for the join between the downpipe and the decat. Annoyingly, this was one of the things I told XS they should provide - and they haven't. C'est la vie.
    One of these should do nicely: 3" Inch 76mm Universal Quality Replacement Performance Exhaust Gasket 2 Hole | eBay
    Homer Simpson
  9. #168
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Anyone who says fitting one of these is a breeze, think again.
    Not an easy job by any means. However, it depends ultimately on how much you want that extra flow.
    So, what makes it such a pain? The arrangement of the holes on the Turbo flange in conjunction with the runners of the manifold simply.
    It is outright impossible to use OEM bolts to mate this, they won't work.
    Use 3 x K04 turbo/downpipe studs. Wind those into the turbo short end first from memory. Makes sure they're tight. Then, when manifold fitted, use 3 stainless nuts (preferably with Nordlock washers to stop them loosening) to bolt the tubo and manifold together.
    One of the nuts (top left of the three) will require a 'special' spanner to actually get to the nut at all. Trust me, it can be done.
    Mani fitted to head:
    'Special spanner'
    Et voila:
    Homer Simpson
  10. #169
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Manifold in use:
    Homer Simpson
  11. #170
    Westy's Avatar
    Dec 2008
    17,264
    Cheers Welly.
    Sorry but I'm still a bit lost with what nuts and bolts are needed?
    As you know I've already got the XS DP and will soon be fitting the mani to a standard k04 turbo.
    I need to ensure I have everything I need before I do this job along with IE rods and large port head.
    S3 Build Thread
  12. #171
    Westy's Avatar
    Dec 2008
    17,264
    Also is it worth heat wraping the mani?
    S3 Build Thread
  13. #172
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    That's a good question! I'd also like to know
    Pat
  14. #173
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Cheers Welly.
    OK, this what you should be aiming to do:
    Would into the turbo in the above pictures are 3 K03 (not K04 sorry - will edit original post) downpipe studs - part number N 907 678 01. Cost around £0.55 each inc VAT.
    I think those studs are M10 thread, so get some stainless steel nuts which mate them from the local hardware shop for pence.
    This way the manifold will slot onto the turbo. Does that makes sense?
    Homer Simpson
  15. #174
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by pats3poa View Post
    Pat
    Not really. I think it's arguable how long heat wrap would last on it, that video shows how hot they get. Also, it is very tightly put together, with very little gappage in between the runners.
    Homer Simpson
  16. #175
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Cheers, should the DP be done?
    Pat
  17. #176
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Pat
    Again, up to you. No harm in the downpipe being done. Don't use cheap heat wrap though, it turns to glass and falls off....
    Homer Simpson
  18. #177
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    My brother (ex mechanic) and a friend (Audi Mechanic) wanna try it with the head on. Who am I to argue its them who will be doing the work for beer tokens.
    2003 Audi S3 + Go faster bits
  19. #178
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by MintyS3 View Post
    Fair enough, I say go for it. It's just always been easier IMO to take the head off. Less hassle, everything accessible. Less scrabbling around in the dark, at the back of an engine.
    Whatever works
    Homer Simpson
  20. #179
    Westy's Avatar
    Dec 2008
    17,264
    That crystal mate thanks. What's different with the standard turbo bolts then?
    S3 Build Thread
  21. #180
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    When you get the mani mate, you'll understand immediately.... Trust me!
    Homer Simpson
  22. #181
    Westy's Avatar
    Dec 2008
    17,264
    Ok mate. I'll order the bolts
    My biggest nightmare is getting everything apart and not having the right parts to get it back together again straight away.
    S3 Build Thread
  23. #182
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yep, I can understand that. OEM bolts will not work. Simple.
    Homer Simpson
  24. #183
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Dont forget that i got you some bolts and washers from bill
  25. #184
    Westy's Avatar
    Dec 2008
    17,264
    So the part number you quoted earlier, is that for the OEM bolts?
    Edit:
    I've just remembered that the standard bolts go down through the top of the mani and scre into the turbo thread.
    I've also just bought 3 new ones from Bill
    S3 Build Thread
  26. #185
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by StaceyS3 View Post
    Yep. The nordlock washers will come in handy but the bolts are useless
    S3 Build Thread
  27. #186
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Edit:
    Part number above was for the studs in the picture, wound into the turbo.
    Homer Simpson
  28. #187
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    should be getting my 3"dp and sports cat fitted tomorrow. I'm just hoping the gaskets arrive in time. If not the place doing it said they can fabricate some as the custom build exhausts..
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
  29. #188
    May 2009
    Midlands
    197
    I see the buy it now on eBay has magically gone up from £380 ish to £450 now :-/
  30. #189
    Sep 2009
    Essex
    2,366
    welly, i saw a yellow s3 on ebay and thought of your bumble bee. good to see youre still pioneering this stuff.
    woodyS3 likes this.
  31. #190
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    I am installing the decat downpipe and the manifold at the moment. will post pictures on a new thread once im done.
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  32. #191
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    Ordered my decat DP a few days ago should turn up today.
    Can't wait to get it all fitted!
  33. #192
    sambryant's Avatar
    seat leon cupra r owner
    May 2011
    bristol
    158
    I am waiting on seeing a std k04 car with decent flowing manifold to see how it goes.
    wellys hybrid luved the additional flow
    not mine by any chance
    BADGER 5 TUNED gt2871, 360bhp 360ftlb
  34. #193
    RIP S3dave
    May 2004
    nr Glos
    7,139
    westies is another in mind.. whichever comes first we will see
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  35. #194
    Westy's Avatar
    Dec 2008
    17,264
    Easter holiday will be the date the XS mani will be fitted but I'll then need to come across to see you again for some dyno action.
    S3 Build Thread
  36. #195
    sambryant's Avatar
    May 2011
    bristol
    158
    guys i have been in contact with usa XSpower (relentless) and i can get these downpipes and manifolds alot cheaper. the new manifold will cost $300 shipped and dp with decat $325 or with sports cat $375.
    these need to be bought through me to get these prices.
    i have also created a facebook advertising this. Log in | Facebook
  37. #196
    sambryant's Avatar
    May 2011
    bristol
    158
    i may sneak in there before. im hoping this feb
  38. #197
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Sam you will have to pay customs and import charges. So prob wonnt be cheaper at all. And tbh, theyre cheap enough.
  39. #198
    sambryant's Avatar
    May 2011
    bristol
    158
    decatted down pipe is around £150 cheaper and sports cat is £210 cheaper
  40. #199
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    Quote Originally Posted by sambryant View Post
    ARGH! SCN are invading, another one! Hey Sam. Welcome.
    For those who are genuinely bothered about flow, I noticed something on my XS downpipe this evening:
    The flange on the end of the downpipe, is 3'' where it joins onto the decat section:
    But then the flange that it bolts to, leading into the rest of the system, is only 2.7'' across:
    So it gives an instant 0.3'' step reduction in the system.
    THe pipe going into the flanges on each side is genuine 3'', but for some reason the second flange has a smaller hole causing a restriction to flow.
    To get around this I'm going to get my dremel out and port out the smaller flange until it matches the bigger flange. Probably a horrible job, but I think it'll be worth it.
    Also worth mentioning that the holes in the flanges are slotted too, so any misalignment when joining them together could also cause a nice stepped restriction.
    Seems a waste to sppend all that money and not fix a few little issues like that, shame XS didn't address these issues though.
  41. #200
    sambryant's Avatar
    May 2011
    bristol
    158
    unless you have a 3" catback then its not worth doing.
  1. S4 decat downpipes
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2011, 20:16
  2. some help please with downpipes
    By sweeney23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2011, 22:43
  3. downpipes are off!!!!
    By s4 osh in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2009, 19:15
  4. Downpipes
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 22:49
  5. AWE Downpipes or Suspension
    By imported_Jibby1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2005, 13:45
