JMB RetrofitsChris Nott
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Exclamation How To: Change Brake Pads
    I've seen the question come up a few times but I've never seen a guide posted...
    So here's a guide for those without elsawin access
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    ptr
    ptr's Avatar
    Aug 2010
    129
    Job is easy apart from needing the piston reset tool, I carefully levered the pads apart using a wrench with no problems.
  1. Parts and tools required to change the brake rotors and pads
    By Jon_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 19:26
  2. Guide how to change brake pads for s3
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:51
  3. Discs and pads change?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2009, 15:26
  4. Discs & Pads change
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2008, 09:18
  5. Brake Warning Light After Brake Pad Change
    By iddyarmin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2006, 20:47
