Monster MotorsportEM Tuning
    Sep 2011
    Tighten or replace serpentine belt A3 tdi
    Hello
    I just want to discuss issues with my serpentine belt (or Alternator/water pump belt) on my A3 Tdi.
    I think it needs tightening more than anything. The reasons I believe this is because:
    - When i turn the steering wheel at stand still it seems harder to turn than what it should normally be
    - There seems to be a slight vibration through the steering when turned
    - The belt sounds like its slipping by making a loud, unattractive squeaking. As soon as i spray some WD onto the belt the squeaking goes away for a day before it comes back again. This would confirm that the belt would be slipping?
    Is there a chance that the belt can be tightened ? I dont think it needs replacing as the belt looks in good condition and i think it was replaced a couple of years ago.
    Any help would be appreciated.. thanks
    Sep 2010
    498
    I need to replace mine, it has some cracks on it so I am going to do it very soon. When the air con is turn on theres a odd noise, very hard to describe, when under approx 1500rpm. I'm thinking it could be the belt or maybe the tensioner.
    I don't know how you'd tighten it. They are on a automatic tensioner. Maybe get underneath and slacken it whilst spraying some grease into the bearings (NOT WD40, this will dry it out) and work it in.
    Hope this helps.
  1. Allroad V6 TDI serpentine belt routing
    By trumpetboy11 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st November 2010, 22:35
  2. HELP how do you tighten the timing belt tensinor
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2010, 15:40
  3. Serpentine belt change
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2008, 16:23
  4. V6 serpentine / auxillary belt.
    By scrupes in forum General Technical / How To
    Last Post: 6th March 2007, 21:03
  5. Serpentine Belt
    By imported_kbininger in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th April 2006, 10:44
