Results 1 to 7 of 7
Thread: Dogbone bush
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    Dogbone bush
    Well i had a productive Saturday, me and my dad (who is a mechanic) got my car on a ramp and fitted new coilovers and wishbones and a service,
    We got the coilovers on fine and wishbones then got it tracked, we was also going to fit my dogbone but the bolts seemed really stiff, my dad said he can try and get them out but they feel like they might snap, I didn’t like the sound of that so i decided to leave it for now,
    Has anyone else had snapped bolts or do they all feel like this?
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    try some wd40 on them leave it on for 30mins let it soak in try again keep doing this also if they move a tad keep undoing and tightening while soaking them in wd40 will ease the whole bolt up.
    another way oxyaceterlean or how ever you spell it lol basically heat the bolts up with the blow torch then they should undo easy
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Are you talkin about the 2 what bolt to the car think size 13? I had a nightmare one snapped on me had a thread stuck in there for a while until it come loose from the mount. There is a topic on here if u search for it. It's happened to a few and others have no problems they advise to replace the bolts after aswell.
    IF IN DOUBT FLAT OUT---iF U AINT RUBBIN U AINT DUBBIN
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    Ye it’s the bolts that bolt into the car, there is no nut on the end of then, if the bolt snaps I would have to drill it out and I don’t fancy doing that.
    I just wondered if it was common for them to snap or if me and my dad were just being women lol
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    No there's no nut on the other end and there's no thread on the mount just the point where it's goes onto car if it was to snap of u can still get the mount of but will need to heat up the remaining thread and use some grips to undo it. Mine was hard to get of the mount and couldn't get it off but it finally come loose one day when I put my foot down.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I sheared a head off a 13mm bolt when removing mine. Lots of heat, wiggling and banging eventually removed the remaining mount.
    Useful thread here: HOWTO: A must do mod - poly dog-bone mount!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Got a set of the red powerflex dog bone bushes on friday so had a go at fitting it last night after work. Managed to get on ok with the 13mm bolts but one of the 16mm into the engine block was a right bugger.
    Managed to get it out in the end and then it was very easy got the new bushes in place and back together in no time at all.
    Engine moves alot less now when rev`d and the gearchange is smoother got a little more vibration at idle but nothing bad and it may settle down after the bush has settled in after a few hundred miles.
    For less than £20 its a good mod i think.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  1. Replies: 8
    Last Post: 17th July 2011, 18:08
  2. Dogbone Bush Problems!
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 16:46
  3. Dogbone Bush
    By edition in forum DPM Performance
    Last Post: 17th February 2010, 13:58
  4. DogBone Mount Bush Replacement
    By mike_plymouth in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2009, 19:43
  5. S3 Dogbone mount
    By Buster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2006, 19:05
