Page 23 of 42 FirstFirst ... 1316171819202122232425262728293033 ... LastLast
Results 881 to 920 of 1643
Like Tree436Likes
Thread: Jardo's pretend S3 build! Now with quattro! with full 'Instagram' updates!
  1. #881
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Soooo.
    I have been getting a small coolant loss, 1 litre every 1000 miles or so. The low level light has never come on, the heaters are up to temp and the climate works, never gone above 90*.
    Today on the way home I had a slightly weird experience, with gently pulling away in first the car went like **** then I backed off, I never asked it to go like that but it just took off.
    After this the car felt slow, and I was convinced I had a boost leak and the car had over boosted. I popped the bonnet and it was hot as **** and the coolant tank was bubbling and had nothing in it. I gently let off the cap and all hell broke lose, the car threw about three litres of boiling coolant out.
    Very strange.
    I refilled and started the car and heard a chattering from the bottom end, immediately I suspected the water pump had sheered. But then I remembered it is a metal one :/
    There is no flow in the header tank, the water is just stagnant.
    There is a little mayo in the filler cap for the oil.
    I took the car for a short drive and it feels down on power until you give it full beans, then it is fine. Doesn't over heat at all, blowers on or off.
    So, any suggestions?
    I quite often say I'm going to do things.
    Then never do them.
  3. #882
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    I'd go with instinct and check Jardo if it was me
  4. #883
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Quote Originally Posted by voorhees View Post
    I can't check it without taking the belt off can I?
    Then never do them.
  5. #884
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Metal impeller pumps have a tendency to leak through the shaft... after not many miles either... every metal impeller pump I have seen has done this... not sure on the coolant problem other than maybe a cracked head... about the only time I have seen the coolant system over pressurise... head gaskets don't normally fail on 20vt's
    <tuffty/>
  6. #885
    burns3's Avatar
    Jun 2011
    221
    <tuffty/>
    Not knowing as much as tuffty about engines obviously but i cracked a head on a 1.2 clio (after buying one trying to be economical which lasted me a couple of months as it was depressing me too much to drive) and it drove as normalish for a few months but used a little bit more water as your using a month but not much more.
    Hope its not a cracked head really for you though.
    Booooooosting just a little bit
  7. #886
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Jardo's new 'Man Boooost' toy!
    Is there any evidence of the original coolant leak? Can you pin point where it was coming from? Has it ever had a full flush of the coolant? Are the rad hoses both getting warm?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  8. #887
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    Quote Originally Posted by 16Klappe View Post
    I'm sure that you can take the thermostat out and check the water pump impellers
  9. #888
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Long finger trick needed
    ​Wish Rachel would let me have my TDI mk5 back
  10. #889
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Bahhhhhhhhh
    Then never do them.
  11. #890
    Sep 2010
    Devon
    752
    Had the exploding expansion tank a few weeks ago on my ibiza, that was the head gasket Hopefully your heads alright though I have two spare if you do need one mate, kleptomaniac lol
    Badger 5 tuned 340 bhp / 350 lbft sleeper
  12. #891
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    Your an A3 so not 100% on that,no ETKA here
  13. #892
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    I just feel so gutted, this thing has been so perfectly reliable for four years. Never let me down once
    And within the space of two months the clutch has gone, the gearbox, every possible mount, now the waterpump and cambelt will need to be prematurely done, potential cracked head and certainly a head gasket.
    Jesus hates me.
    Then never do them.
  14. #893
    Sep 2010
    Devon
    752
    Jesus doesn't hate you, besides now may be a good time to find solace in religion...preferably buddism or something that teaches inner peace.
    Be positive, after 4 years of trouble free motoring and abuse its expected to have a few things to deal with. Needn't cost the earth and thewhole car will be nearly new again
  15. #894
    Sep 2012
    Devon
    843
    Quote Originally Posted by slowcoach3 View Post
    Very true, ive tried to explain, if it is the HG its no biggy, and will cost parts, and poss red bull and a few fags
    come on, you boys need to keep me busy, otherwise id do something silly like get Rach up the duff or such like lol
  16. #895
    Aug 2011
    Plymouth
    604
    Add Lavis89 on Facebook
    ahh your past few months reminds me of my entire experience of mk2 golf ownership, bought it for £350, spent 2k on it, sold it for £300 a year later still not running properly after everything possible went wrong about 3 months after i brought the damn thing.
    dont worry phil i'll be popping out to tavi soon, summer is comming and mine needs to be running tiptop!
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
  17. #896
    May 2010
    Bedford
    2,877
    Got some coilovers that need fitting so drive to Bedford please... Don't do a silly thing like have a child lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  18. #897
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Jesus hates me.
    I dont think this flat shifting/Launch control business is kind to the engine, it is soon going to show a weakness
    Apart from that Jesus may hate you....
  19. #898
    Feb 2011
    Plymouth
    937
    Welcome to the world I used to have. Lets hope nothing else happens after.
  20. #899
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    Launch control?
    MAN BOOOOST?!?
    LOL!
    Westy likes this.
    You've got to have a laugh!
  21. #900
    Sep 2010
    Devon
    752
    Quote Originally Posted by phil miller View Post
    Don't joke, I need mani, fmic, lg porthead and turbo doing.....plus Jards workload, Rach is safe for a while
  22. #901
    Sep 2012
    Devon
    843
    Thats what i like to hear dude
  23. #902
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,000
    Add MIGGZ on Facebook
    Sh1t dude I'm sorry man, that's really a crap feeling dude
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  24. #903
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,062
    I think the key thing you're forgetting here mate, is that it hasn't been your car for the pst 4 years, it's been Lous.
    It's had an easy life, a simple st1 remap, and it's trundled around town for a few years and done the odd long trip.
    In the 4 months that you've owned it, you've added a front mount, an exhaust, a st2 map with launch control. You've hugely increased it's output, and you hammer it about everywhere, so I think it's fair to say it's had more abuse since you got it in october than it has in the last 4 years
    Sad, but most definitely true.
    Westy likes this.
  25. #904
    Loupigs's Avatar
    69
    As ever, Prawn is the voice of reason. The reason I gave the car up was because it was coming to a point where it needed money spent on it and I had neither inclination nor funds to throw at a 10 year old car (yes I know it's a great 10 year old car, but that was my decision). I knew as soon as I drove it the other day there was something not right, and absolutely it's not a surprise that now the car has been pushed further power-wise that other things were going to fail. I hadn't spent any money on it for a year and had done nothing more than pootle from one side of the city to the other 5 days a week. Poor thing. Never did it justice and then I gave it to this hooligan!
    You aren't stuck in traffic.... You are traffic
  26. #905
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,298
    Quote Originally Posted by Loupigs View Post
    Lou, you can live with the Knowledge that you treated it well in all the time your had it. Jardo, what can i say, i have to agree with your good lady, your just a hooligan, lmao.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
  27. #906
    Sep 2012
    Devon
    843
    Its gonna be ok, a day or to on life support and it will be fine, the A3 is in good hands, promise Lou
    But im sure Ron is its twin, ive got to A3s outside on life support
  28. #907
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    It'll be ok, and it'll come back stronger than ever. I'm not giving up on the baby like Lou did, I knew **** was going to go wrong but I just hadn't counted on it going wrong this quickly and all at once.
    I've got Phil Miller, and as Prawn said earlier nothing is a problem when you've got Phil on your side
    New water pump, cambelt and compression test, fingers crossed that'll sort it. Total worst case we'll have to do the head, not the end of the world.
    And if it looks this good broken, imagine how awesome it is working -
    Then never do them.
  29. #908
    Sep 2012
    Devon
    843
    ^^^ made me 'well up' thank you dude, and as bad as it sounds im only doing my job, i dont see that as anything amazing, both A3s will be fine, may take a few hours hard work but it will be A OK when all done
  30. #909
    Loupigs's Avatar
    69
    Wow this thread is getting emotional... Who would know Philler is such a softie! Sorry to hear about Ron mate.xxx
  31. #910
    Aug 2004
    Kent, UK,
    66
    Nice! Except for that exhaust. Ugly, sorry!
  32. #911
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    On a cheerier side note, hows the tiger sealed mounts doing mate?
  33. #912
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Tiger sealed mounts are awesome, get it done.
    The plan was to do the rest of my polybushes yesterday but obviously with my over heating issue it didn't happen. I can't wait to get everything done and get it back on the road.
    Going to work in the 500 this morning and then Lou is taking me to Russ's to pick up a head tonight.
    Then never do them.
  34. #913
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    140
    Gutted to hear you've had issues. As Nick says I suppose it's just one of those things when you start getting much more than standard power from an old car. Good luck with getting it fixed, I'm sure Phil will do a good job of it. Look on the bright side, whatever bits need replacing, it'll be a few more parts that you know are fresh and good. 'Better the devil you know' and all that. Even if they're not up-rated it's still added piece of mind for the future knowing they're sound.
    Occasionally I wish I had shiny paint I could pamper, your car does look damn good all polished up. (Then I remember I'd probably just neglect it anyway while I was playing with the oily bits.)
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
  35. #914
    Oct 2012
    121
    Sorry to hear about the issues. But remember, with great power comes great responsibility!
    Im starting to fit the S2K filter this weekend. Did you have any joy fitting a heatshield? Would the S3 Dave one not fit?
    i may buy some sheet metal and attempt to fab one up. But I'd only have a drill and tin snips to try. Drilling a 70mm hole for the maf would be a nightmare!
  36. #915
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    I don't know why everyone bothers with the heat-shield personally.....
  37. #916
    Oct 2012
    121
    with only 185 ponies I don't want to run the risk of any running away. Into lasagne.
    Its more sonething to support the maf with. And bolt the ignition amp to.
  38. #917
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    While stopping the heat is questionable, the fact that it holds the MAF solid is without doubt a good thing, plus there are no pikey cable ties hanging around..
  39. #918
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    I don't have any pikey cable ties!
    Then never do them.
  40. #919
    May 2010
    139
    I think the fact it hold the MAF steady and looks pretty negates the fact you might lose 1 G/S.
  41. #920
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Quote Originally Posted by demons uk View Post
    If you knew how many heat shields I have you'd understand that g/s is everything.
    And I've got another two in the shed...
    Then never do them.
  1. help with quattro cutting out
    By mikehoncho in forum General Technical / How To
    Last Post: 27th November 2007, 21:12
  2. towbar for avant with quattro/vortex rear bumper
    By pablo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2007, 16:53
  3. A3 Quattro with RS4 Alloys?
    By a3tdiquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 01:18
  4. Newbie with Quattro V8 and questions
    By quattrov8 in forum Classic Audi Forum
    Last Post: 28th January 2007, 18:36
  5. quattro with vf28
    By qttro in forum Classic Audi Forum
    Last Post: 4th May 2004, 09:51
