Monster MotorsportChris Nott
Results 1 to 8 of 8
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Aftermarket HU with Bose?
    Who here has Bose in their S3? When you changed the unit for an aftermarket one, did it sound better or the same as the standard Audi HU?? I've got a concert stereo so not sure if it will make any difference?
    AJ
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I'd also like to no the answer to this...
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    S3 Paul's Avatar
    Oct 2006
    2,764
    Ive got bose set up and now have an alpine DVD headunit,
    The sound in my opinion is stronger and better
    Noggy Blue 2001 S3
    SunnyB's Avatar
    May 2011
    West London
    65
    I don't have a bose system in my a3 but I'd assume it would sound better. With the wiring adapters you would still keep the standard sub/amp running and the speakers (rear) running through the amp so there won't be any loss of sound/power. Most decent head units give you more options to adjust the sound, ie more than just the normal equlisers would (jazz, rock, pop etc).
    Most new headunits will also be 4 x 50 watts minimum nowadays too. Whats the output on the standard stereo?? If power rating is the same then there probably would be much difference but again, you will still have more flexibility of how you want it to sound in your car.
    A3 1.8 T AGU
    EXTERIOR : Debadged Grill / Tailgate, 18" RS8 Rims, Facelight Rear Lights, Angel Eyes
    INTERIOR : Retrofit Mustard Heated Leather Interior, Armrest, White SMD's, Carbon Wrap, Red Ambient Lighting
    ENGINE : Forge 007p, Pipercross Panel Filter, Stage 1 Remap
    CHASIS : 35mm Jamex Lowering Springs
    ICE : Kenwood KDC-BT61U Headunit, Front; Hertz DSK 130, Rear; Infinity 6529i, JBL Sub & Amp
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    Quote Originally Posted by SunnyB View Post
    Most new headunits will also be 4 x 50 watts minimum nowadays too. Whats the output on the standard stereo?? .
    this is what i was going to say, the OEM HU will have low power output so when you turn it up the quality reduces, a new HU will be 4x50wt so it will go louder and sound better,, this will highlight the fact that the speakers are naff but when both the OEM HU and an aftermark HU are compared at the same sound level the aftermarket one will sound much better
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    I was happy enough with the sound of mine after fitting my Alpine HU... I have since fitted a lot more kit but tbh other than more volume and better bass from the Andy Mac sub I could have just got away with fitting the the AMSS and Alpine and been happy enough...
    <tuffty/>
    Jgould's Avatar
    MY ARS3!!!
    Sep 2009
    Slough
    74
    I took out my tv hi and put the standard hu back in but I also put a 12" alpine swell as the standard Bose set up the louder if gets the better it sounds!! IMHO the concert system with the extra sub sounds loads better than after Market hu. I used to run tv + 2X12" subs and infinity mids + tweeters in my cossie and the sound was not as good as the Audi but that could be the difference in the car build quality
    MY ARS3!!!
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Thanks people. Looking at a new HU soon so at least i know it will be better!
  1. Aftermarket HU for S3... What bose adapter do i need?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2012, 18:56
  2. Fitting aftermarket headunit into S3 with Bose
    By LukeTripod87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2011, 22:58
  3. Bose with aftermarket headunit
    By vetch in forum In-Car Entertainment
    Last Post: 26th April 2009, 16:55
  4. Replies: 8
    Last Post: 7th February 2007, 18:38
  5. Aftermarket Bose Upgrade
    By 1600sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 10:45
