Results 1 to 14 of 14
    Apr 2011
    Dublin, Ireland
    614
    Exhaust fitted and wow
    Well after the bit of trouble I had after fitting the exhaust, the car is running fine now. But holy moly it has absolutely destroyed my mpg. It has literally halved it and for not much of a gain in power, it has me thinking is it really worth it. I mean when giving it the beans my mpg goes down to 3mpg where as before I put it on it never dropped below 12. While cruising I am only managing at most 30mpg compared to 45+ before.
    So I am no contemplating going back to the standard unit. Has this happened to everyone who has changed up.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    No how can it? something wrong, ive got a pipewerx with no probs, reset the adaptions....
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    12mpg when giving it some how.
    i have standard exhaust when booting it i only get 3-4 mpg, sure it aint blowing some where
    Smokey_clark's Avatar
    12th Gear
    Nr Bath
    211
    I have standard exhaust, mine drops to 3-4 when giving it some. Lucky to get my average above 30!
    What exhaust is it btw?
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    maybe you just have apply more pressure to the loud pedal when driving, MPG is suppose to increase with a map, mine has done the opposite lol
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Quote Originally Posted by Syvo View Post
    i would check for this too
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    colicabcadam
    you've knocked something / unplugged something - most likely the lambda sensor or possibly the exhaust gas temperature sensor if your car has one?
    changing an exhaust system will not see a drop of mpg by 33% lol, if 33% more fuel is being pushed in it'll put pressure on the cat, do you smell like a clutch burning smell, this will be the cat trying to break down the excessive fuel!
    Apr 2011
    Dublin, Ireland
    614
    Reset which adaptions.
    There is no cat in the system anymore. There was deffo nothing left unplugged after the install.
    There are no leaks along the pipework/joints.
    RIP S3dave
    May 2004
    nr Glos
    7,143
    mpg determined how? off mfa or tank to tank (reliable)
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Totally normal what your getting now. Expecting over 30mpg from a 260hp (guess) car, lol
    Apr 2011
    Dublin, Ireland
    614
    I wouldnt say that. The fuel economy increased after the Revo map, so the only parameter to have changed since then is the exhaust which as I said in the first post I think has probably ruined the car. Anyway when on part throttle you aint using half the power the engine can produce, yet the mpg has fallen right off.
    Before fitting the exhaust I was averaging 320-340 miles per tank, now I just managed 205miles on the last tank. Now that is a huge drop dont you think. Yes the foot has been planted a few more times than usual, but only a couple of times otherwise I have been driving the same.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Dave what engine codes your car?
    After fitting my 80mm tip the mpg dropped to about 18mpg and that was granny driving, after about 80+ miles with it fitted the mpg has come back to level pegging, around 30mpg mixed driving.
    Suck.Squeeze.Bang.Blow
    Jul 2011
    Madchester
    228
    Quote Originally Posted by dannyh View Post
    Haha in this case he's on about the exhaust affecting his mpg, not his remap :P
    Aug 2011
    devon
    I have cat back exhaust, forge tip and I get average 26 mpg (based on dash display) but I have a heavy right foot !
    2001 S3
    Mods.. Forge quickshift (forward/side), Forge TIP, Cat back exhaust, Retro fit Cruise control, Induction Kit, n75 J, ECU remap.
    Need more power !!
  1. New Exhaust Fitted :-D
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2011, 13:06
  2. new exhaust fitted
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2007, 18:41
  3. Exhaust Video Fitted
    By mazzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2006, 20:46
  4. Anyone fitted their own exhaust?
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2005, 10:04
  5. New Exhaust Fitted
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 19:16
