Monster MotorsportBadger5
Results 1 to 11 of 11
    s3matthewd's Avatar
    Jan 2011
    79
    audi s3 quattro downpipe
    just wondred if anyone could help me my brothers going to make my downpipe and decat because his day job is as a fabricator,could anyone show me a picture or tell me if i need a 3 bolt flange or a 4 bolt one car is 2001 bam engine code many thanks matt
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Sure its 3 bolt mate.
    s3matthewd's Avatar
    Jan 2011
    79
    just wondred if any one had a link for one dont want to order the wrong one also would 3 inch be overkill for turbo back or ok
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Here you go mate:
    Google Images
    s3matthewd's Avatar
    Jan 2011
    79
    thats brilliant cheers
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    No worries mate.
    Aug 2011
    160
    Quote Originally Posted by s3matthewd View Post
    3" seems the only way to go these days. Made a 3" downpipe for a mk4 which had a BAM k04 turbo and that worked really well.
    Audi A3 1.8T AUM Sport with more doors.
    s3matthewd's Avatar
    Jan 2011
    79
    ok then do i need a location for the second lamba sensor or can i leave it out i no i can get the light mapped out when i go stage 2 and also will the car go into limp mode with this mod or not thanks matt
    beachbuggy's Avatar
    Surrey
    1,746
    If your getting a custom made downpipe, weld in a O2 sensor bung anyway. Gives you the option to use or loose the 2nd O2 sensor. If it's not required then you just plug it, easily removable if you change your mind or sell the downpipe. Plus the parts just a few £'s!
    s3matthewd's Avatar
    Jan 2011
    79
    also looking at the picture on google images above do you think that i would really need that flexi joint in the pipe work or could i get away with that thanks matt
    Apr 2011
    Dublin, Ireland
    621
    Yes you will need the flex joint.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
  1. Audi A5 Sportback 2.0T Quattro downpipe?
    By danielescobarg in forum A5/S5/RS5 Forum
    Last Post: 3rd June 2011, 17:52
  2. gt28rs downpipe for quattro?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2011, 21:55
  3. 2.0 Tdi Quattro De-cat downpipe? Anybody know where to get one
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2011, 19:27
  4. Downpipe for A3 Quattro?
    By tyson in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2010, 12:50
  5. Downpipe for A3 quattro
    By quattro rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2009, 16:44
