Volks AutosMonster Motorsport
    Sep 2011
    New to the site, help needed!
    Hi I'm Mitch. I drive a '98 A3 1.8T sport.
    I went to have my car remapped yesterday but they couldn't do it as I had several fault codes. It's also turns out the previous owner has disabled the engine management light.
    The codes are;
    16500 - Engine Coolant Temp. Sensor (G62): implausible signal
    P0116 - 35-10 - - - Intermittent
    17978 - Engine Start Block by Immobilizer
    P1570 - 35-10 - - - Intermittent
    00561 - Mixture Adaptation
    14-10 Adaption Limit (Add) Exceeded - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    26-10 - Output Open - Intermittent
    The thing that has me confused is that I have no physical problems with the car. It's boosting between 8 - 9 PSI, it's not got any lag and the idle is fine.
    Any advise into how to fix any of this is greatly appreciated.
    ( Sorry for the really long first post)
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    You need clear the faults really just to see if they come back or have you done that
    I am here: http://maps.google.com/maps?ll=53.187470,-2.532764
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    The car probably doesnt have an engine management light.
    Before you do anything, clear all of the codes and see which ones come back. They may be old codes.
    The Coolant one could be a faulty thermostat or a faulty sensor. Does the guage climb up to 90c and stay there? or does it fluctuate as you speed up and slow down. If it fluctuates its likely to be the thermostat, and its pretty common for them to fail at this sort of age.
    Immobiliser ones probably irrelevant.
    The next two could indicate an air leak, ie a split hose or similar.
    Last one is either a broken or disconnected tank vent valve.
    TD5 Land Rover Defender build
    Sep 2011
    They erased them for me but i have no access to a vag com until Thursday so unsure if they have returned.
    Can the engine management light be disabled using a vag com or has the bulb been physically removed?
  1. new to site
    By davS3 in forum The Welcome Section
    Last Post: 24th May 2011, 16:33
  2. What's that site??
    By will89 in forum General Automotive Chat
    Last Post: 9th February 2011, 10:40
  3. After trauling through this site... bit of adivise needed...
    By A3-sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 22:23
  4. Web-site about the new Q7
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st July 2005, 10:04
