Sky InsuranceChris Nott
    Mar 2008
    Hull
    89
    engine code help part 2
    hi guys
    just a quick question, will a BAM code bottom end block fit into my 99 s3 engine code APY. will the head bolt to it ok and will all the APY pipes etc meet up to the BAM block?
    thanks in advance
    dom
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Block wise you will be fine.... APY is an 06A block like the rest of the range but the 210/225 blocks (IIRC) have slightly thicker webbing to make the block stronger over the std K03 turbo'd engines...
    <tuffty/>
    Mar 2008
    Hull
    89
    Thanks tufty much appreciated
    dom
  1. Replies: 4
    Last Post: 2nd March 2011, 12:56
  2. what gearbox code matches engine code ASV
    By sjfedex in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 19:18
  3. Coil pack part number? Engine code?
    By Mikebabs1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2007, 13:21
  4. MAF Part code Please
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2005, 14:55
  5. Help with a part code please?
    Last Post: 3rd September 2004, 16:48
