    Sep 2010
    498
    12v cigarette lighter socket in boot guide?
    Has anyone on here installed a 12v lighter socket in the boot like how the mk4 golf has them? Would like to see a guide if there is one about. I have had a search on here but couldn't find one.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Not installed one but shouldn't be too difficult.
    Buy a 12v socket ideally from a Golf but obviously any will do. Drill a hole in the trim and install it. Run a feed from the front Cigarette lighter's fuse in the fusebox by splicing a wire in. Run the feed to the back of the car and solder to the socket. Run an earth from a seatbelt mounting point or another suitable earthing point.
    If the front socket runs only when the ignition is on, the other socket will be the same. You can take a permanent live (but make sure it's fused) if you want it to run even with the engine off but cool boxes are pretty energy intensive.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Sep 2010
    498
    Ah ok. Yes probably best to take it from the front cig lighter i suppose. Was hoping there would be a good source in the boot rather than try and run wires all that way. I intend on using for yes cool box and sometimes a 240v adapter for charging camera batteries. Might be doing a euro road trip!
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by doublem_1 View Post
    See if this helps:
    Waks Wide Web
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Chugger
    North Devon
    2,716
    Iv thought about this as my golf had it, but the 'higher quality' a3/s3 doesn't,
    Maybe come off power feed to amp for sub, that should be permanent live, then just fuse it. My cigarette lighter is perminately live regardless of ignition position.
    57 A3 2.0 TDI Sportback (140)
