Badger5Monster Motorsport
Results 1 to 28 of 28
Like Tree1Likes
  • 1 Post By markthenewt
Thread: Removing the turbo from an A3 Quattro the same as an s3?
    Mar 2011
    Warwickshire.
    246
    Anybody know if the removal of a turbo from an a3 Quattro 8L is roughly the same as removing the turbo from an S3 due to them both having the transfef box thing under the turbo?
    Looking for a D.I.Y guide but not having much luck.
    I have started to strip my car down, so far got the exhaust and downpipe from the turbo off, charge pipes off,top manifold nuts off and a few other bits.
    I have read that the worst part to get off is the turbo bracket.
    Could do with a guide if there is one about as I have been searching for a couple of days and not having much luck.
    Cheers.
    A3 quattro Sport
    Forge 007p Pipercross panel filter R-Tech stage one map (213BHP)
    Oil catch can mod, SIA delete, EGR valve delete. Forge EGR delete plate.
    Mar 2011
    Warwickshire.
    246
    I have found a guide for removal of a turbo from a Audi TT Quattro. Should be the same?
    A3 quattro Sport
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by TheNewt. View Post
    Yeah should be mate, alot of people take the head off believe it or not....
    Mar 2011
    Warwickshire.
    246
    Cool... Yeah I read it's easier with the head off but sod that lol as I only had my cambelt changed a couple of months ago so don't want to be upsetting that and buying new head gaskets and bolts, I'll go down the scraped hand route.
    The guy who done it on the TT did not remove the head so I'll just wing it.
    Wish me luck lol, doing it on the drive and it's wet and windy, need it back on the road asap as I start a new job next monday.
    Not decided where to send the turbo off to be refurbed yet either, CR turbos keep popping up, any thoughts on the best place to send it?
    Cheers.
    A3 quattro Sport
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Mar 2011
    Warwickshire.
    246
    Cheers for the link Dave. I'll have to give them a call to get a rough estimate.
    If I send to CR it's going to be a minimum of £225 upto £395 for them to repair it.
    CR said it might work out a bit cheaper having mine repaired rather than buying one of there refurbed units for £395.
    I'll let you know how I get on and keep my progress updated here.
    A3 quattro Sport
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Removing a K03 is a whole lot easier than a K04... last one I did took less than an hour... no need to remove the head on K03 turbo'd engines...
    The most awkward manifold nuts are either side of where the turbo bolts on so you will need to unbolt the turbo to mani bolts and undo it from the turbo supprt bracket... the coolant pipe running round the front of the cam belt cover is held on by a 10mm bolt on a bracket at the back of the block under the mani, you 'can' bend this a tad to get easier access to the mani nuts behind but I normally unbolt it and drop it down... exhaust mani is then lifte out the top and you have easy access to the turbo and all the oil/coolant pipes... undo the downpipe from underneath
    <tuffty/>
    beachbuggy's Avatar
    Surrey
    1,744
    no no no
    No, a3 quattro isn't like the tt or s3 for the simple reason you don't need to remove the head off the quattro to get the turbo off. Yes the turbo can be removed from an s3 without the head coming off but it's a right pain.A3 quattro is the same as the the a3. Just remove the exhaust manifold and lift the turbo out. Turbo bracket is holding the turbo in place with a 13mm bolt. Oil and water lines are a little tricky but believe me I'd change an a3 turbo ove an s3 or tt any day off the week!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Quote Originally Posted by beachbuggy View Post
    ... but believe me I'd change an a3 turbo ove an s3 or tt any day off the week!
    amen to that brother!
    <tuffty/>
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    740
    Any chance of a link to the guide TheNewt??
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Mar 2011
    Warwickshire.
    246
    Quote Originally Posted by &lt;tuffty/&gt; View Post
    Removing a K03 is a whole lot easier than a K04... last one I did took less than an hour... no need to remove the head on K03 turbo'd engines...<br>
    <br>
    The most awkward manifold nuts are either side of where the turbo bolts on so you will need to unbolt the turbo to mani bolts and undo it from the turbo supprt bracket... the coolant pipe running round the front of the cam belt cover is held on by a 10mm bolt on a bracket at the back of the block under the mani, you 'can' bend this a tad to get easier access to the mani nuts behind but I normally unbolt it and drop it down... exhaust mani is then lifte out the top and you have easy access to the turbo and all the oil/coolant pipes... undo the downpipe from underneath<br>
    <br>
    &lt;tuffty/&gt;
    Cheers mate :L yeah I have all the manifold off now, was not too bad to do really and everything else like all the brackets and stuff off.
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    This made me lol mate I wish it was as easy as just remove the manifold and lift the turbo out haha and the rest.
    Typical I am stuck on the turbo bracket bolt now, the last bolt to undo. Do you tackle this from cambelt side of the engine or the other side? I can see it from that side but it's awkward as the thread is sticking out so need to get a longer 13mm socket
    Cheers mate.
    Edit.... been trying to get the wrong bolt lol, I was trying to get that bolt above the driveshaft, the bracket bolt is further in, off I go to try again.
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    Quote Originally Posted by sportquattro View Post
    Yeah no worries mate, here it is http://homepage.mac.com/bhardt/audicontent/K04-install.pdf
    Y
    ou don't need to take the driveshaft out or split the exhaust in the middle section, just undo the cat to downpipe nuts then you can just push the exhaust back just enough for clearance.
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    Another guide here aswell but i'm using the one above... http://homepage.ntlworld.com/kevin.y..._K03_Turbo.pdf
    666markyboy likes this.
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    Grrrrr I have had to down tools as the turbo bracket bolt is tight and I will end up breaking it... Fresh start in the morning... there's allways one eh.
    A3 quattro Sport
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Yeah, they do that
    Plenty of penatrating fluid mate and being a quattro you can't just unbolt the bracket from the block as the sodding bevel box is in the way... booo
    gl for tomorrow
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Aye joys of motoring, good luck x 2
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Try Midland Turbo, They rebuilt mine with a 360 bearing for the right money
    Home | Midland Turbo
    Black S3
    Mar 2011
    Warwickshire.
    246
    Thanks guys.
    Not looking forward to removing this bracket bolt at all. Is it tight because all of the weight from the turbo is now resting on this last bracket bolt? I fear I'm going to break it or round the end off. It was easy up until this bit :/
    Thanks for the link of the turbo repair too Jack :L
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    I'm thinking put the manifold back on with a couple of nuts then put the 3 manifold to turbo bolts back in the turbo, this should take the weight off the turbo bracket bolt and make it a bit easier to undo as all the weight from the turbo wont be on it?
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    Been trying for hours now still can't get this last turbo to bracket bolt undone
    Anybody want a job lol.
    A3 quattro Sport
    Mar 2011
    Warwickshire.
    246
    And then it happened, my worst nightmare, the nut rounded off. Don't know what I'm going to do now... I could cry
    A3 quattro Sport
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    O no
    the only thing left to do is drill it!!
    Mar 2011
    Warwickshire.
    246
    Quote Originally Posted by dannyh View Post
    O no
    Yes seems so or just smash it which is what I feel like doing now, so annoyed!!!
    It's tight down there, I doubt I will get a drill in but will try, If I could put a new bracket on I could just wobble and break the old one off but I can't do that as I can't put a new bracket on. It has 2 allen key bolts holding the bracket on but I can't get to them because the front diff is in the way being a Quattro.
    I wondered if it would be ok without the bracket as the turbo will be held onto the manifold with the 3 big bolts but apparently running it without the bracket will cause the manifold to break.
    Gutted
    A3 quattro Sport
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    try some stillis and a screwdriver pry the turbo whill undoing the bolt with a set of stillis or file two sides of the nut/bolt so its flat on two sides then can undo with a spanner, had this happen numoruos times and found one of the two methods ideal depending on room
    Mar 2011
    Warwickshire.
    246
    Syvo there is no way you can get into the bolt, the only way you can get at it is with a long 13mm socket with a few extension bars on it.
    Cheers for the shout though. I googled "stillis" as I have never heard of it before and nothing comes up, what is stillis?
    Anyway my mate is coming to the rescue later tonight with some of these Bergen 3/8" SD 12mm Rounded Nut Bolt Extractor Socket | eBay It's grips the bolt as more force is applied so should have the turbo off tonight
    A3 quattro Sport
  28. #27
    Mar 2011
    Warwickshire.
    246
    Finally got the bolt out today, such a releif.
    My mates bolt remover would'nt grip as it was a half inch size and not a true 13mm but then I managed to borrow a proper 13mm bolt remover and it came out.
    Thought it would end up an engine out jobby... Phew lol.
    Just waiting for my turbo to arrive now, should hopefully be here tomorrow, if not it will be Monday.
    I Had to go to the hospital after as I got a bit of metal in my eye. I did have goggles on while doing the work but once the bolt was out had to recover a socket and foolishly went under the car without the goggles.
    Eye is sore but ok now.
    Cheers.
    A3 quattro Sport
  29. #28
    Oct 2011
    Swindon, Wilts, England, UK, Europe, THE WORLD
    51
    Out of interest "stillis" are these stilson wrench - Google Search
