Following on from sandips logging session this week, I've put a new bosch MAF in and I'm still getting slightly low readings (154g/s) following a full throttle 3rd gear run. Anyone had this before?
1) check for boost leaks in hoses (even the slightest cut from an over-tightened jubilee clip can cause this). Check all hoses around / under DV etc.
2) Check DV - does it seem OK (holding boost etc.)
When was it last serviced (when was air filter last cleaned)?
Serviced last month, air filter good. Dv is not a standard one (but is a recirculating one). Have leak tested it recently and only found one leak which is now fixed
Join the gang mate, i've had a leak for a few months now and still can't find the ******* thing. Looks like i'm gonna have to get a pressure test done!
