Badger5AH Fabrications
Results 1 to 10 of 10
    Sep 2005
    Derbyshire
    180
    Electric Windows!!
    Hi Everyone,
    Today's issue (not had one for a long time).
    Got in the car at lunch time and put the drivers window down, heard a clunk and the window dropped pretty quick, I pressed it back up and it slowly came back up making a god awful noise (like broken glass) however the window itself is fine, not broken, smashed or craked.
    Is this the window regulator? I belive the motor is fine as it did come up using the button (I had to help it on the last inch or so).
    Car is a 1999 Audi S3 APY.
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    it could be the clips holding your glass to the regulator frame, these are a common problem and happened to me, the only way to find out is to take your door car of and have a look, it only takes 2min to remove the door card,
    if it is the clips there are two at the bottom of the window and they fasten to the wires behind, just have a feel to see if its snapped, then buy new ones or fix with cable ties like I did, 1 year on and it’s still fine
    Sep 2005
    Derbyshire
    180
    Hi Danny,
    I'll have a look after work, The sound of Cable Ties intrigues me, better than £50+ for a regulator and £15 for some plastic clips.
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    Quote Originally Posted by Blackcupraa View Post
    Hi Danny,
    ye that was my thoughts, i just drilled four holes and criss crossed the cable ties to hold the clip
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Here's the how-to to take the interior panel off:
    Audi A3 Electric Windows Fix
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    clip has snapped
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Sep 2005
    Derbyshire
    180
    Quote Originally Posted by dannyh View Post
    Before I start where do you drill the holes? is this on the inner door skin?
    Sep 2005
    Derbyshire
    180
    Okay, door card removed.
    At the bottom of the door there is a white plastic connection with a spring attached (goes to motor) which then leads to the bicycle cable (what is it's proper name?) which goes around the "sub frame" of the door, this then has a black covering over the bicycle cable which has corroded in the connector on the bottom left of the door, as you look at it from the inside.
    I assume this means I need £50s worth of regulator?
    Feb 2008
    2,817
    Just what I needed to read. Cheers guys. This has happened to me. Might have a crack at this this weekend.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    a3tdi2001's Avatar
    437
    The lovelies at Audi wanted £100+ for a regulator IIRC. You can buy one of these and DIY.
    AUDI A3 8L ELECTRIC WINDOW REGULATOR FRONT - RIGHT | eBay
