New clutch advice - S3
mattyboy199
UK
Guys,
I m due a new clutch its now slipping in 3rd & 4th under full boost. I intend to replace the clutch & fly wheel together but what i need to know is what else should / or can be done, my list so far compirses of.
1. Clutch (standard item)
2. Flywheel (dual mass)
3. Release bearing
4. Slave cyclinder
Never had to replace a clutch before so i m a complete novice in this area.
Matt
Personally I wouldn't try it yourself unless you know what it is doing and have done it in a workshop environment.
But, strip it down and assess the wear. Nobody on here will be able to tell you what you need without seeing it.
my mistake, i ll be getting a techie at audi to do a private job, but 1st off i need a tick list to make sure his price includes everything (worst case).
only looking at clutch related parts jus not sure what they all are and if my list in the first post is correct
Luk standard clutch with a SMF like the one andrew@ald is running, thats what im planning on getting.
748
6
12
388
