AH FabricationsChris Nott
Results 1 to 11 of 11
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Part Number Needed Please...
    Does anyone know the part number for the side skirt clips on the s3? Mine has come loose at the very end...I am assuming this just clips back on?
    S3-2003-BAM-MING BLUE-SILVER LEATHER
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    8L0 853 909, CLIP
    Hope that's what you're after
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Sometimes the bit that the screws go into on the side skirt actually part company which means that the door blade comes away from the door. If you remove the door blade ( 4 screws on inside edge of the door and slide door blade to remove from lugs on door) you can glue the fixing strip using epoxy glue back into the door blade and then refit to the door which should now be nice and flush.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Tried glue its not stuck looks messy now
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    worked ok for me but did use lots of glue to get the strip to stay in the door blade.
    Has the strip on the inside of the door blade come away at the end nearest the rear of the car?? as this seems to be most common guess it gets knocked more opening the door etc.
    Im not 100% sure but i thinki the strip that the screws hold into in my car was part of the door blade so if not fixable it would need a whole new one.
    Good luck on your fix
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    691
    Mine has also done the same. I think a blob of glue and some tape to let it set should do the trick.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Anyway, it was a pleasure, don't mention it
    Suzuki GSX-R 750 K5
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    can you buy these and fit them to an A3????
    LukeTripod87's Avatar
    Apr 2009
    Kent
    325
    ^^ You can indeed!
    2010 S3 Sportback
    Miltek cat-back non res / soon to be wrapped!!.....
    **Message for parts enquiries in Kent**
    dannyh's Avatar
    Nogaro S3
    Jul 2009
    Manchester
    783
    is it easy???
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    I have bought the clips from Audi 58p each
