JMB RetrofitsEM Tuning
    kevscotty's Avatar
    Aug 2011
    19
    Headlights 8l A3..
    Thinking about changing headlights but in the meantime may look to tidy up exisisting ones..
    Is it possible to buy just the clear plastic from the front of the headlight to replace?
    and
    Will all s3/a3 headlight models fit my 2000 A3?
    cheers folks
    May 2011
    80
    are yours the lights with indicators in them? i.e facelift headlights or same as earlier models which have seperate indicators?
    ptr
    ptr's Avatar
    Aug 2010
    129
    you can refurbish the current ones with some wet and dry sandpaper and polish. there's a thread on here with pics somewhere.
    kevscotty's Avatar
    Aug 2011
    19
    The headlights and indicators are all contained in the one unit..
    Would try wet and dry sandpaper method but looks like an electrical buffer would be needed to do a proper job,
    the reason i want to change the fronts is that the drivers side is condensation filled with a water stain on the inside and when
    trying to clear using full beams the passenger side platic began to crack and warp slightly..
