EM TuningChris Nott
Results 1 to 9 of 9
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    718
    Bilstein B8s & Eibach Springs
    Well the good old S3 has shat on me again, 2 broken rear spings and a perished vaccum hose to the brake servo, such are the joys of a 11 year old 100,000 mile S3.
    Rather than just replace the 2 rear springs it seemd pointless not to upgrade the whole suspension, so a phonecall to DPM Perfomance at 15:00 yesterday resulted in a nice set of Bilstein B8 dampers and Eibach spings arriving today at 10:00 thats pretty awesome service from DPM Performance so mightily impressed here.
    Hoping to fit them myself next Saturday, does anyone on the forum have any hints tips or suggestions as to potential pitfalls to watch out for or nifty tricks of the trade. Are the any other bits that I should replace as a matter of course? Top Mounts for example?
    Any advice welcome, particularly if it doesnt involve my having to spend any more on expensive parts.
    Thanks in advance
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Remember to undo the headlamp level sensors for both the front and back, they are both on the passenger side. Whilst the front suspension is off, I recommend you change both strut tops and bearings, the kits are around £25 from ECP/GSF, you might want to consider lowering spring plates/cups also for the fronts for an additional 10mm drop, as the Eibachs don't seem to drop the fronts much, but they ride very nicely.
    You've got to have a laugh!
    Oct 2010
    Netherlands
    10
    Excellent choice. I also have the B8's with Eibach springs, it is a good upgrade for the S3 . Still comfortable with good handling.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    Think you need a deep 17 or 19 mm spanner / socket that you can get a allen key through. I purchased a socket and ground 2 flats on it so it could be hled by a spanner then use the allen key through the top. (thats for the front).
    Rears are easy might only take 1 hr to complete both sides.
    Fronts are straight forward if you have done simular before, might be worth spraying everything with wd40 now so its well soaked for when you do the job.
    red to red black to black blue to bits
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Did it set you back much Nige?. this is something ill be looking into in the near future, Youll have to take me for a spin through the twisties.
    Aug 2011
    160
    Use loads for WD40 on those front hubs and a short bit of pipe that you can hammer on to. What Eibach springs did you go for 30mm or 50mm ones?
    Sep 2009
    718
    Quote Originally Posted by MrCSW View Post
    Hi Callum
    They were £639.95 delivered from DPM Performance, ordered them Friday at about 15:30 and they arrived 10:00 the next day. Will gladly take you for a spin when fitted buddy, I've still, got to send you the ETKA DVD and whilst I think of it i've bought an ultrasonic cleaner to clean my injectors, so if you want to do yours at the same time let me know and we can arrange a time mate.
    Nige
    Aug 2011
    136
    Is the standard suspension on the S3 really poor? alot of people seem to be upgrading
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    ^^ Not that poor, just getting tired as most are around 10years old now.
    We'll definatly have to catch up at some point when were both free Nige.
