Spankys3
Hey all,
can anyone tell me where this sensor is located on the block? I am getting a 16711 fault code up. There is a wire the runs with the injector loom that is not plugged into anything. its had a 2 pin plug on it. So as the fault code means low signal volts could this be the issue.
J
J
