Hey guys,
Any help would much appreciated if possible. Basically this bit of my headlight connection has melted through and obviously doesn't work anymore on my headlight.... (The connector to the xenon lamp)
I have managed to source a new headlight with all the connections - BUT apparently the ballast (the metal ecu box type thing) on this pic
may be broken or it could be the bulb itself. The seller isn't sure which doesn't help and can't test it. Does anyone know if it's possible to swap out my connector (which has melted) to his connector which hasn't melted. Can't work out from the pic above if the wire from the metal box unscrews or pulls out?!
My ballast works perfectly you see.... Presumably ballast's and transferable from headlight to headlight?
Anyone ever done it before? Thanks - nothings ever easy is it!
Any help would be much appreciated.
