Badger5Volks Autos
Results 1 to 7 of 7
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    expansion tank boiling after use
    hi iv searched for hours to find a similar prolem but havent found one yet.
    basically whenever i use my car it drives fine at the temp guage sits nice and steady at 90 as it should and never passes that but when i turn the car off i can hear the water in the expansion tank boiling like a kettle and its obviously very hot there too. i checked the thermostat and that is working perfectly so not the problem,
    i checked the water pump and although it was in perfectly good order i changed it to a new one with a metal impellar.
    i also checked the rad and big hoses for blocks by running a hose through thm but good flow.
    i did find a load of browm sludge in the expansion tank so cleaned that thoroughly
    but once i re-assembled the car the promblem still remains
    does anyone have any ideas they would be greatly apreciated
    andy
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Maybe a faulty seal around the expansion tank?
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    i did find half an oring in the tank actually the size of a 10p but i dont know where its come from or where the other half is
    colicabcadam
    change the lid of the coolant chamber, chances are it's lost its air tight seal - no pressure = lower boiling point
    with an air tight system, i believe the boiling point of water / coolant is something like 125c
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    ok thank you i will give it a go
    colicabcadam
    they are only like £5 too
    Smokey_clark's Avatar
    12th Gear
    Nr Bath
    211
    Quote Originally Posted by colicabcadam View Post
    What he said..
