Sky InsuranceEM Tuning
    Aug 2011
    Kirkham
    11
    ASZ Engine diagram
    Hello,
    Does anybody know where could I find an engine diagram/cut-out for an ASZ block?
    Trying to find where does the port seeing it from above when the rocking cover is off between cyl 2 and 3 goes, straight to the sump box or not.
    Thanks a lot
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    I guess this isn't any good ?
    Aug 2011
    Kirkham
    11
    Thanks voorhees
    Saw that one, it's a start. You guys might have a laugh about it, but basically I dropped something in that port and I'm not sure if it goes straight to part 23 or down 34. It's lodged in the port half way down right now, it's a spring from the injector harness. I'll try to hook it up tomorrow with a coat hanger and see how that goes.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    Hey its no laughing matter,I've seen the result of a nut left in a tip by accident,doing work on an engine in your garage is admirable....I struggle getting my ashtray out let alone taking a cylinder block apart
    Aug 2011
    Kirkham
    11
    Seen similar results too so. Shouldn't be a problem with a mix of good old metal coat hanger and a magnetize screwdriver hopefully or i'll drop the pan and part 23, oil change is due anyway
