EM TuningVolks Autos
Results 1 to 8 of 8
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Strange Temp Issues
    Got a strange one on the S3.
    After driving for 10 minutes yesterday, glanced down and noticed the temp gauge was on zero
    Then it rapidly shot up to 90, then back down, then back up??
    I changed the stat about 2 months ago but the symptoms for that where never hittting 90 and always sitting around 70/75 so I don't believe its the stat again.
    Could this be the Temp sender? Scanned the car but its not showing as a fault?
    Ideas?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Yes, sounds like a dodgy temp sender. Have you checked the temp with the climate control?
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hi dude hopefully its the sensor but my mate had a 210bhp cupra r and it had very similar symptoms with the temp gage reading 75, he changed the temp sensor 3 times to no avail, he put it down to a faulty ecu, or because he had a water pump failure he thought maybe bits of plastic had been screwing around inside bloking sensors and the like. He never sorted it and ended up selling it.
    Nov 2008
    154
    +1 for the temperature sender
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by camscockle20vT View Post
    That sounds like the thermostat tbh, did he not change that?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Sandip is bang on the money. See what the temp is showing using the Climate Control Panel.
    How to display car speed on Air Con display?
    The temp sender is fairly cheap and is a hell of an easy job compared to the stat
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2010
    1,673
    Yes mate forgot to put that in, he changed all manner of things to no avail, even took it to the steelers and they said it could be an ecu problem, car was jinxed lol
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Changed the temp sensor today and so far so good! It was the old black style that was in it so I bet it had been there for a good while!
