Chris NottEM Tuning
Results 1 to 10 of 10
    Aug 2011
    Somerset
    26
    electric recaro problems
    Hi I own a 2000 S3 210bhp, the front electric recaro on the drivers side has developed a fault, as in the up/down adjustment of the seat only work on the down operation.
    Is the switch at fault or could it be something else?. How easy is it to fix , i tried getting the toggle switches off but to no avail, Help please !!!!!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Likely cause is a stuck microswitch in the innards of the seat. They are there to cut the motor off when the seat gets to max or min height. They can fail or get stuck so the system thinks it is at max height when it isn't.
    It's not an easy fix at all as you have to dismantle a lot of the seat to get to the switch, although there are some guides on here.
    I have to admit I tried as best I could without taking all of the sub-frames and seat base off but it didn't work for me and it still won't go up.
    It's really annoying as the seats are very heavy (around 35kg) and not the easiest thing to man handle in and out of the car and I was petrified of scratching something. You don't know if what you've done has worked until you plug it all back in again. I still haven't been to the dealers to work out if the microswitches are available as spares or not.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    There you go, the bit about recaros is page 72-116 onwards in the A3 interior manual that you can download from here:
    http://users.ox.ac.uk/~engs0330/car/a3_interior.pdf
    Jason
    Aug 2011
    Somerset
    26
    cheers, my local Audi specialist can do it but its going to be £180.00, bit steep but saves me a lot of hassle!!!
    spencer-s3's Avatar
    2nd gear
    Oct 2010
    Bridgend, United Kingdom
    63
    Quote Originally Posted by tward11 View Post
    your mad paying that mate.. i fixed mine just by putting my hand under the seat & pessing the button on the micro switch they aint that hard to find... the one that stops the seat going up is on the side closest to the door just behind the switches & the down one is on the inside by the seat belt clip both stapped to bars,
    have a feel around & you will find them they only need a little tap & they are fixed
    Aug 2011
    Somerset
    26
    dont suppose you have any pics as i cant find the switch to press!!!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Need to do this on mine, was a paasenger in my the other month and realised the up/down doesnt work.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I did fix mine in the end but didn't take any piccies - sorry - but there is a verbal description in this post:
    S3: Front driver seat will only go up - not down?
    The microswitch is 4BO 959 985, retail at the moment is £17.24 + vat.
    Jason
    Aug 2011
    Somerset
    26
    still cant locate them switches arrgghh
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Sorry - I should have taken some piccies when I did mine. Have you looked at the A3 interior manual? I know the diagrams can be a bit obtuse but they do help - honest.
    Jason
