AH FabricationsSky Insurance
    imported_razputin
    Do I need to reset the ECU???
    I have had problems with my A3 1.6 SE when the engine has been idle, constantly dropping rev's etc. All the same problems that most of you guy's seem to have had at some stage or another. Have replaced the MAF, which has helped a bit, & intend cleaning out a lot of the ducts/pipework surrounding the MAF on the weekend. I'm also going to try cleaning the throttle body which I've heard may also help fix my idling problem. Any how, was wondering if I do complete all this work, will I need to reset the ECU or should it automatically adjust itself?
    Would this be the correct procedure to (hopefully) fix my idling problem?
    Ps. Is the throttle easy to remove/reinstall?
    Razputin [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Re: Do I need to reset the ECU???
    reseting the ECU only means disconnecting the battery for say 1/2 hour
    would not hurt if u are carrying out some work
    had my throttle body cleaned at dealer and it made the idle much much better - mine was hunting and revs cutting off when braking approaching junctions
    i am told my MAF still has a few faults and will need replacing but have not seen them re-appear yet so fingers crossed (the MAF is notorious in VAG engine )
