Sky InsuranceEM Tuning
    Apr 2011
    Dublin, Ireland
    621
    Plastic piece under accelerator
    Is there any advantage to removing or cutting back the piece of plastic under the accelerator pedal.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Do you have 'drive-by-wire' or 'drive-by-cable' - whereas wire is electronic throttle.
    I have been informed that on a 'drive-by-wire' this makes no difference because of where the pedal stops (checked it myself and this appears true) but I think i took mine out anyway.
    Kristian
    No longer an Audi driver...
    a3tdi2001's Avatar
    437
    8l's are drive by wire so shouldn't make any difference.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Quote Originally Posted by a3tdi2001 View Post
    Only 1999 onward 8L's are drive by wire, earlier ones are cable throttle.
    Apr 2011
    Dublin, Ireland
    621
    Thanks. So I guess its staying.
