Chris NottAH Fabrications
Results 1 to 11 of 11
Thread: switches
    MickA3's Avatar
    Oct 2004
    Dublin
    98
    switches
    I installed a post fit fog light kit from VAGparts yesterday [img]/ubbthreads/images/graemlins/cool.gif[/img] and as i didn't use the OEM switch i have a generic toggle switch under the steering wheel....what i'm wondering now is- i have three 'dead switches' to the right of my hazard warning light button- what do these buttons usually do? I would like to get an active button to replace one of the dead switches with and then use it as my fog light switch- is this possible?....also if anyone has a part no. for a switch that goes there i would appreciate it!! (i assume these switches would be 15 amp rated plus)....cheers in advance for any help!!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: switches
    The "dead" switches or "blanks" as they are known are for heated seats, ESP etc, depending on the model.
    The fog lights are usually connected to the headlight switch. You pull out the switch to operate them.
    Does you switch pull out?? If so then you can connect them to it to be like they came from the factory.
    MickA3's Avatar
    Oct 2004
    Dublin
    98
    Re: switches
    Hi, sorry blank switches is what i meant! .... yeah my fog light switch pulls out once for the rear but not twice for the fronts (this is how i uderstand it to work- correct me if i'm wrong!)- and the replacement switch is very pricey....so i'm thinking of getting e.g. an ESP switch and using it to operate the fog lights- is there any reason i couldn't just do this??
    1,361
    Re: switches
    I don't see why not, it would do just the trick.
    Got a nice fog light set-up a while back which has a remote for it, so all the wiring can stay under the bonnet. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: switches
    Yup, you could use an ESP switch etc, or you could get hold of a two position headlight switch.
    Either would work fine.
    Oct 2003
    up north...
    767
    Re: switches
    all the audi switches are momentary - that is they connect only whilst pressed
    you will have to make up a latching relay circuit that keeps the relay closed after 1 push then opens after another.
    MickA3's Avatar
    Oct 2004
    Dublin
    98
    Re: switches
    I hadn't thought of that!! Is that easy enough to do? ....
    Can anybody give me the part number for one of the ESP switches to fit a 2001 A3.... my dealer is hopeless [img]/ubbthreads/images/graemlins/bang.gif[/img]....
    Oct 2003
    up north...
    767
    Re: switches
    is it a facelift?
    MickA3's Avatar
    Oct 2004
    Dublin
    98
    Re: switches
    [ QUOTE ]
    is it a facelift?
    [/ QUOTE ]
    yeah- its a 2001 facelift model
    Oct 2003
    up north...
    767
    Re: switches
    do you have an esp switch in there?
    the left and right blanks have no available switch from audi - there was never anything that was designed to go there on the facelift models
    the middle one is usally esp - assuming that you dont already have anything there i will check the part number for you
    MickA3's Avatar
    Oct 2004
    Dublin
    98
    Re: switches
    Thanks Dunk! .... i have no esp switch there- i just have three blanks in a row....
