Chris NottBadger5
    Feb 2003
    41
    Wheel allignment after changing to 18\'s
    Hi guys I have got 18" Zender Monaco cup alloys on my A3 and michelin pilot sport 2 rubber on them. After 2 thousand miles I have began to notice that the inside of the tyre is wearing more than the outside, I'm just wondering what I need to. I have asked a mechanic and he said that I should first try using longer bolts as the I had used the standard bolts that came with the 15" se alloys that the car came with as standard. If that fails then I should take the car to kwikfit or similar and get the allignment sorted. I have not lowered the car as yet but I would like to do this as the car is sitting a tad high and would look much better with a small drop, however I've heard that most people who do this have to get the allignment sorted anyway. So am I better off to just get the lowering springs fitted and put longer bolts and see what happens or what would you guys suggest?
    Oct 2003
    South Wales
    2,942
    Re: Wheel allignment after changing to 18\'s
    Sounds like your tracking is out mate. Take the car to a garage and get this adjusted before you wreck your tyres. Should cost approx 15 - 20 depending on where you go.
    Rich.
    Feb 2003
    41
    Thanks. Will let you know how it goes.
