Monster MotorsportBadger5
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Nilz
Thread: Audi S3 headlight washers dont work. Is there a relay?
    Jan 2011
    10
    Hi, My headlight washers have stoped working. I have checked the fuse but that is fine and i have put power to the pump and that is fine. there is no power going to the pump. Is there a relay for this? and has anyone got a diagram for the relay box? Thank you
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Just confirm that you are trying it with the headlights on, not just the sidelights - the main headlights need to be on, otherwise they will not work.
    yellow s3 likes this.
    S4 Muzza's Avatar
    oww! my giant blue head!
    May 2011
    Ayrshire
    306
    mine dont work either and haven't since i got the car, doesnt really bother me though. the sloution? a damp cloth every now and again, jobs a good'un!
    Audi S4 (B5) - JUST ARRIVED :D
    Audi S3 (8L) - GONE
    Audi A3 SE (8L) - GONE
    talentwalsh's Avatar
    May 2010
    Galway
    139
    No relay, they work off the pressure from the water. There is a slight delay while your waiting for the pressure to build. If they still dont work its probable the pump in the washer bottle itself is gone.
    Jan 2011
    10
    hi sorted it 2day there is a relay its under the dash on the drivers side in position 5 n 6, its brown colour relay. It is a multifunctional relay that controls the headlight washer and wipers. It is about £30 from audi. I will post the part no. If anyone wants it but it is on the relay. Now its all fixed
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Nice one glad your sorted...i think they burn out in sub zero temps when everthing is frozen,
    rob irl tdi's Avatar
    Jul 2010
    241
    Anybody else had this?
    Would it come up in a vcds scan?
    2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by rob irl tdi View Post
    Nope...
    <tuffty/>
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I've got this.
    Fuse ok, pump seems ok, no voltage at all gets sent to the headlight pump.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Mine was like this and a new pump sorted it, although i never checked the voltage butthe pump was shot to ****.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    When I can find an appropriate bit of wire I'm going to apply voltage directly to the pump to make sure that's ok, but my tests show the car is sending no voltage to the pump - ignition and headlights on, fuses checked.
    I already have a new pump just in case.
    I think it's the relay, but I don't know which one. I have two part numbers for relays which might be the culprit 4B0 955 531 E and 8L0 955 535. I need to take the cover off to see what relays I actually have.
    I'd really like a proper wiring diagram for this car so I don't have to guess all the time.
    Liam
  1. 1999 audi s3 headlamp washers dont work
    By leess3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2011, 21:09
  2. Headlight washer jets dont work, what could be the problem?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2009, 10:21
  3. Headlight washers ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2007, 23:57
  4. How Do Headlight Washers Work?
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2005, 20:16
