Sky InsuranceBadger5
Results 1 to 10 of 10
    Jun 2010
    London
    94
    8L S3 Lighting Help Request
    Hi guys,
    I would like to replace my yellow-ish side lights with some white LED ones that don't throw errors. Can anyone recommend a good reliable set and where I can purchase it? Not after any blue-tinted ones...just want white ones that go well with the xenons.
    Also - cleaning the headlights - is there a way to freshen them up a bit? Mine seem a bit cloudy, and I have a feeling it needs a clean on the inside and out. Is it quite easy to dismantle and carry out?
    Any help appreciated.
    Thanks.
    Current: Audi S3 (2002) in black...
    Previous: Renault Clio Williams 3 (1995)
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    i bought 360 xenon sidelight bulbs from ebay, they work fine on my S3 and look good with the 5000k headlight bulbs, and dont throw up codes either
    Nov 2008
    154
    I've had these and now these
    Both worked fine and have done for a while. I was a little apprehensive about the hong kong ones but they are bright, arrived pretty quick, fit fine, and are still working after about 2-3 months. I like the look of them, although they make your headlights look yellow.
    Just look on ebay for the cheapest ones really, ensure they are 'error free' or 'canbus' ones so the computer doesn't think there is a bulb out. Check feedback and lok carefully at the pictures, some are visibly of low quailty.
    Jun 2010
    London
    94
    Cheers guys.
    How do they look when the lights are off? Do they stick out like a sore thumb within the headlamp?
    Nov 2008
    154
    They don't really stand out at all, I thought they would but I never notice, you have to actually look inside the headlight which isn't really a common thing to do, if that makes sense.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    ive never had a canbus warning for a front sidelight failure in 8 years of ownership, even when both front sidelight bulbs failed?
    i have these>>>clicky<<<
    Jun 2010
    London
    94
    Quote Originally Posted by Endacy View Post
    They make your lights look...yellow?
    Nov 2008
    154
    Yeah just because they are so white when on, the headlights by contrast look yellow next to them.
    Jun 2010
    London
    94
    Wow...they must be VERY white then...I thought my xenons were pretty white!
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Bare in mind it's still daylight so they don't look bright, mine are the same as the link I posted earlier and the headlights are 5000k, if your headlights look yellower they must be factory 4300k bulbs
