Monster MotorsportEM Tuning
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    engine problem need some advice/ help
    Made a post a few days ago, about my engine has developed a problem. Its getting more common now. When pulling away for a second has no power feels like its stalled. Or sometimes when putting a bit more load on the engine. 3rd/4th up a steep hill. It only does it at times, and some times it can be fine. Its got full service history. Oil changed every 6 month or 5K which ever first. All new filters and plugs sept 2010
    Its not showing up any fault code. Will sit on -20 vac and will still boost as normal.
    Anyone got any idea?
    Thanks Jay
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    beachbuggy's Avatar
    Surrey
    1,745
    Check for air leaks. if there's a leak in the intake or vac pipes, you'll get a flat spot.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    All the vac pipes have been replaced for silicone not really a flat spot, its a almost total loss of power for a split second then its fine again.
