Chris NottMonster Motorsport
Results 1 to 10 of 10
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    Unhappy S3 Seat/ seat subframe removal
    So my passenger seat has become a bit wobbly and i found today that a piece of black plastic that the seat runs on is to blame, as you can see from the photo its broken in half!
    It goes here;
    And here it is, still intact, on the other side of the same seat;
    Has anyone else replaced one of these? Im having a trouble getting the seat out, i have disconnected the battery and removed the 4 6mm allen bolts in the runners but the seat doesnt want to come out. Im assuming i have to first remove the seat itself and then the subframe after??? I have the A3 interior workshop manual but it seems the set up is different on the s3? Thanks.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Put the allen bolts/cap head screws back in.
    Undo the two screws under the plastic cover under the front of the seat, then remove covers at the end of the runners and you can then slide the seat back and it does come out.btw there is two connectors which need unplugging under the seat.
    If your unsure I'll get a pic
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    Managed to get it out now, thanks.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Quote Originally Posted by dellboy View Post
    Ahh good news
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    Anyone know where this piece goes?!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Not sure if this is the same manual, but the S3 Recaro instructions are towards the bottom (page 72-116)
    http://users.ox.ac.uk/~engs0330/car/a3_interior.pdf
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Sep 2010
    Whitehaven, Cumbria
    59
    Dellboy did you every find out where this piece goes? Iv got the seat out of mine and have the same spare piece. Iv got no idea where it goes and i cant load up that manual. I know it was a while ago but hopefully you remember
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    Sure did mate! There is a cord on a ratchet springy type thing, that is housed in plastic, the cord is under tension and helps when you want adjust the seat forwards or backwards. The end has like a plastic hook on it that hooks onto this metal piece... Sorry the explanation isn't so clear, it's difficult to explain, and as you said it was a while ago. If you can't sort it let me know and I'll try again! Good luck.
    Sep 2010
    Whitehaven, Cumbria
    59
    Perfect!!! job done, cheers dellboy
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    No worries, glad you got it sorted.
