Volks AutosAH Fabrications
Results 1 to 22 of 22
    Nov 2004
    Tonbridge, Kent
    912
    AMD Diverter Valve..
    Who has got one of these and do you notice any difference?
    I am thinking of getting the piston valve fitted and was just wondering peoples opinions.
    Are there any other options?
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: AMD Diverter Valve..
    Ive got the viper DV fitted. No real noticeable gains (still std 225), although acceleration through gear changes feel smoother and I am sure it sounds better.
    PaulS3's Avatar
    UK
    1,003
    as above.
    fitted a 3mm spacer in mine to firm up the spring a little and hold boost longer/ snap shut sooner and it seems to work well.
    tried thicker and didnt like it.
    Oct 2003
    South Wales
    2,942
    Rob,
    It wont give you any performance gains, it will just be more reliable than the Bosch diaghram ones. And serviceable too!
    Rich.
    Nov 2004
    Tonbridge, Kent
    912
    Cheers for that. Can if fit the 'N' revision bosch valve to my 1.8T or does it only fit an S3?
    Thanks again
    Rob [img]/ubbthreads/images/graemlins/ok.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    Thanks again
    [/ QUOTE ]
    you can fit it no problem! All VAG petrol turbos use the same size valves!
    Rich
    Nov 2004
    Tonbridge, Kent
    912
    Cheers Rich [img]/ubbthreads/images/graemlins/ok.gif[/img]
    PaulS3's Avatar
    UK
    1,003
    [ QUOTE ]
    [ QUOTE ]
    as above.
    [/ QUOTE ]
    My AmD Viper has been in my car for over a year and I haven't touched it.
    Should I be servicing it?
    Also, where can you get these spacer from? I take it AmD do a service kit?
    [/ QUOTE ]
    I service mine quite regularly just because i can.
    I started off with service kits from AmD then sourced my own O-rings (x3) and experimented with a couple of high temp greases.
    as for spacer, i started off with a couple of washers, that i bolted together and filed down whilst in a drill to get the right size, , then just placed them under the spring, but in the end, i got a selection of ally spacer rings machined at work to do the job.
    circa 3mm works a treat.
    http://www.wak-tt.com/mods/dvshimming/dvshimming.htm
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    I've ordered the service kit which will include an uprated spring. Will using a spacer/shim still be necessary?
    PaulS3's Avatar
    UK
    1,003
    its purely a personal thing.
    if there is an uprated spring,
    (i didnt know of this, its never been in the kit before) then you probably dont.
    let us know how you get on with the new spring.
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    How much do these kits cost as i think mine will need to be done v soon.
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    What grease do y'all typically use on the DV?? I tried a high-temp ceramic (Vs Copper) and didn't think it worked as well as it should've [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    [ QUOTE ]
    [/ QUOTE ]
    12+vat delivered from AmD.
    That kit comprises of an uprated spring and o-rings as well.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    Re: AMD Diverter Valve.. *DELETED*
    I think an uprated spring will only benefit if you are running high boost.
    taj
    May 2004
    33
    Take a look at this mate might help.
    http://www.audi-sport.net/ubbthreads...&page=1#125127
    Taj
    PaulS3's Avatar
    UK
    1,003
    good [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Signature is the standard spec, not the modded one [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    [ QUOTE ]
    [/ QUOTE ]
    Care to share your modded spec?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    I've received the service kit and uprated spring. What sort of grease is best to use when servicing?
    UK
    289
    AMD told me they didnt need servicing until something like 100k miles...do they specifically say they need servicing?
    Dunc
    PaulS3's Avatar
    UK
    1,003
    for the time it takes, not to mention the peanuts cost , why not service it
    Dunc.
    your always after the best performance, get and service it.
    its constantly moving every time you open and close the throttle and gets to quite a temperature too
    i was told more like 10K miles, but its such a quick job, i just do it as and when i feel like it.
    never found anything wrong with it, in either sticking, dry, or damaged o-rings, but its nice to know its all free and lubricated.
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    The best would probably be a NLGI 2 high temp grease of some sort, but in all honesty a multi-purpose Lithium or Molybdenum sulphide grease would do the job.
    UK
    289
    Do you have to buy a service kit for the Forge valves?
    Dunc
